Tip & How-To about Computers & Internet
CD/DVD Drive Icon Is Missing
When your CD/DVD icon is missing from the my computer window and your CD/DVD drive is no longer reading any type of media, please follow this simple steps:
Microsoft Windows XP
Click Start, and then click Run. In the Open box, type regedit, and then click OK. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Then, delete the upper and lower filters
Microsoft Windows Vista
Click Start, and then click All Programs. Click Accessories, and then click Run. Type regedit, and then click OK. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Computers & Internet Logo
my laptop doesnt have the cd drive. It doesnt read my cd or dvd..
If you have more than one computer and other computer has dvd drive or cd drive you may use it by networking this computer to that one! You may also by external cd/dvd drive for your computer as well which may be easier!
Sep 14, 2011 | Computers & Internet
windows cannot execute sndvol32.exe
Method 1: Add the Volume icon loadTOCNode(2, 'resolution'); To add the Volume icon to the notification area of your computer, follow these steps:
  1. Click Start, and then click Run.
  2. Copy and paste or type the following command in the Open box, and then click OK: mmsys.cpl
  3. Click to select the Place volume icon in the taskbar check box.
  4. Click OK.
If the Volume icon is displayed in the notification area of your computer, you are finished. If you cannot add the Volume icon or if you receive an error message when you try to add it, the Sndvol32.exe file might be damaged or missing. Go to method 2.
Method 2: Save a new copy of the Sndvol32.exe file on your hard disk loadTOCNode(2, 'resolution'); If the Sndvol32.exe file is damaged or missing, you must extract a new copy of the Sndvol32.exe file from the Windows XP CD and save it on your computer's hard disk. Prerequisites loadTOCNode(3, 'resolution'); This method requires you to have your Windows XP installation CD.
Note If you do not have access to the Windows XP CD that contains the installation files, ask the network administrator for help if the computer is at your workplace, or contact Support. To contact Microsoft Support, visit the following Microsoft Web site: http://support.microsoft.com/contactus/ (http://support.microsoft.com/contactus/) To extract a copy of the Sndvol32.exe file from the Windows XP CD and save it on your computer's hard disk, follow these steps:
  1. Insert the Windows XP CD into your computer's CD drive or DVD drive. Press and hold the SHIFT key as you insert the CD to prevent it from starting automatically.
  2. Click Start, and then click Run.
  3. Copy and paste or type the following command in the Open box, and then click OK: cmdThe command prompt opens.
  4. Type the drive letter of the CD drive or DVD drive, type a colon, and then press ENTER. For example, if your computer's CD drive is drive E, type the following, and then press ENTER: e:
  5. Copy and paste or type the following, and then press ENTER: cd i386
  6. Copy and paste or type the following, and then press ENTER: expand sndvol32.ex_ system_root\system32\sndvol32.exeNote system_root is the path and folder name where the Windows system files are located on your computer. This is usually C:\Windows. If the folder that contains the Windows system files on your computer is C:\Windows, type the following, and then press ENTER: expand sndvol32.ex_ c:\windows\system32\sndvol32.exeNote There is a space between "ex_" and "c:\windows" in this command.
  7. Type exit to exit the command prompt, and then press ENTER.
  8. Verify that you can start Volume Control and that the Volume icon is displayed in the notification area (if you selected this option in method 1).
Jan 07, 2011 | Computers & Internet
My computer dropped my DVD/CD Drive and I need to know how to find it
The CD/DVD icon would be missing
* Your CD or DVD Drive does not read or write and is shown as disabled
* The media in your CD or DVD drive cannot be read
* The media cannot be written to by your CD or DVD drive
* You receive one of the following errors:
A class specific or device specific driver is missing or corrupt
A CD or DVD drive cannot be found or is not connected
The CD or DVD drive is experiencing a problem
that prevents it from working properly
The CD or DVD drive is not accessible via an assigned drive
letter
This happens due to a variety of reasons.
This can be fixed, by rectifying some registry entried
Microsoft has a free utility to automatically run, to get this fixed : access this at : -
http://support.microsoft.com/kb/982116
http://support.microsoft.com/gp/cd_dvd_drive_problems
Or try the rectifying the registry by following the steps in the link above.
Sep 20, 2010 | Computers & Internet
Laptop Optiarc DVD RW AD 7530 B is not reading CD or DVD media. 1.DVD icon displayed in My Computer. 2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off within few seconds. 3.DVD drive in My Computer when clicked shows empty folder 4.Uninstalled DVD drivers in Device Manager and let windows find it on reboot 5.Issue still persists. 6.Right now external DVD RW works perfect. Please help
Please help
Oct 29, 2009 | Sony NEC Optiarc AD-7530B 8x DVD?┬▒RW DL...
volume icon in taskbar
You experience one of the following symptoms on a Windows XP-based computer:
* The Volume icon is not displayed in the notification area at the far right of the taskbar.
* When you try to add the volume control icon to the notification area, you receive the following error message: "Windows cannot display the volume control on the taskbar because the Volume Control program has not been installed. To install it use Add/Remove Programs in Control Panel. "
Therefore, you cannot start the Volume Control program and cannot adjust the volume and sound level settings of your computer.
There are two possible causes of this problem:
* The Volume icon has not been added to the notification area of your computer. (The Volume icon is not displayed automatically when you first install Windows XP.)
* The Sndvol32.exe file is damaged or missing.
Solution:
mmsys.cpl
4. Click OK.
Prerequisites
To extract a copy of the Sndvol32.exe file from the Windows XP CD and save it on your computer’s hard disk, follow these steps:
cmd
4. Type the drive letter of the CD drive or DVD drive, type a colon, and then press ENTER. For example, if your computer’s CD drive is drive E, type the following, and then press ENTER:
e:
cd i386
Note: system_root is the path and folder name where the Windows system files are located on your computer. This is usually C:\Windows. If the folder that contains the Windows system files on your computer is C:\Windows, type the following, and then press ENTER:
Hopefully the Volume icon is now displayed in the notification area.
Jul 18, 2009 | Computers & Internet
275 people viewed this tip
David Payne
David Payne
