Tip & How-To about Office Equipment & Supplies
Error Code iR2200 / iR2800 / iR3300 / IR3100
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Error Code
Detail
Code
Error Name/Explanation of Error
E000
0000
The reading of the main thermistor does not reach 30°C 1 sec after the main power switch is turned on. Or, it does not reach 70°C 2 sec thereafter.
E001
0000
The main thermistor detects 250°C or higher.
0001
The main thermistor or the sub thermistor detects overheating (hardware circuit detection).
0002
The sub thermistor detects about 295°C or higher.
E002
0000
The temperature of the fixing film is as follows:
· has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
· has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
· has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
E003
0000
The main thermistor reading is lower than 140°C when paper is moved.
0001
Low fixing temperature detection after standby (by sub thermistor)
E007
0000
An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100°C or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven.
E010
0000
After the main motor drive signal is generated, the clock signal does to arrive within 1.3 sec.
E014
000
After the fixing motor drive signal is generated, the clock signal does not arrive within 1.3 sec.
E019
0000
The waste toner case is full of waste toner.
E032
0001
The DA unit connection is disconnected (after connection).
E051
0000
At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
E064
0000
The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer has deviated from a specific level of voltage.)
Error code e000
If it is a Canon please try this URL
http://testprinter.net/fix-error-code-e000-on-canon-printer-system-error-e000.html
Jul 28, 2016 | Office Equipment & Supplies
HOW DO I SOLVE CANON IR 2002N ERROR E000-0000
Provide an explanation of the error code documented under Troubleshooting i can help
Jun 25, 2015 | Canon Office Equipment & Supplies
IR4570 error code E000 - 0024, please help
hai my name is aslam the error code E000 has been fixing unit.replace the unit
Oct 03, 2010 | Canon iRC3100 Printer
274 people viewed this tip
jasbo
jasbo
