Tip & How-To about Computers & Internet
How to check if your system needs drivers
WINDOWS XP
Goto Start > Run > type "devmgmt.msc " without quotes and hit the enter key. You will get Device Manager opened. Now see if you see any yellow exclamation mark. If you see yellow icon that means the current drivers are corrupted or the drivers are not installed.
To fix the issue use windows update site and install all the hardware updates.
WINDOWS VISTA & WINDOWS 7
Goto Start > In Search type "device manager " without quotes. > Now locate device manager and open it. Now see if you see any yellow exclamation mark. If you see yellow iconthat means the current drivers are corrupted or the drivers are notinstalled.
To fix the issue goto control panel and open widows updates and install all the hardware updates for your system.
Computers & Internet Logo
after installing windows 7 the sound drives were not working , no sound
Check Device Manager to for any "unknown devices", your audio device driver might be one of those. Unknown devices usually appears if the device driver (ex. audio driver) is not installed. You can also find an "exclamation point" under "Sound, video and game controllers" if there is conflict on the driver causing no audio to be heard from the unit.
To resolve the issue, you can either use the Drivers installation disc which came with the motherboard or Right-click on the "unknown device" and select "Update driver" button.
For pc users who doesn't know how to check device manager, follow below steps:
Windows XP
- Start > Run > type devmgmt.msc on the box then hit enter key. or you can also
- Start > Right-click My Computer > Properties > Hardware tab > Device Manager
Windows Vista and 7
- Start > type devmgmt.msc on the search box then hit enter key or
- Start > Right-click Computer > System Properties > Device Manager (link at the left pane)
Hope this helps.
Jun 06, 2011 | Computers & Internet
sound not working
To resolve the issue, you can either use the Drivers installation disc which came with the computer or Right-click on the "unknown device" and select "Update driver" button.
For pc users who doesnt know how to check device manager, follow below steps:
Windows XP
Windows Vista and 7
Hope this helps.
Jun 06, 2011 | HP Compaq nx9020 Notebook
no audio device
Check Device Manager to for any "unknown devices", your audio device driver might be one of those. Unknown devices usually appears if the device driver (ex. audio driver) is not installed. You can also find an "exclamation point" under "Sound, video and game controllers" if there us conflict on the driver causing no audio to be heard from the unit.
Windows XP
Windows Vista and 7
Hope this helps.
May 06, 2011 | Dell Dimension C521 PC Desktop
No sound after Windows XP (SP3) Black install
go to device manager remove check if no yellow sigh audio device of pci device. remove that and refresh allow new hardware search and install driver manually.
Mar 29, 2010 | Microsoft Windows XP Professional With...
No bluetooth devices detected om my laptop
Check there is a switch to "On" the bluetooth device..and if its 'On'  then goto device manager by typing devmgmt.msc at run and hit the enter key and check if bluetooth is listed over there........
Sep 15, 2008 | Compaq Presario Laptop
207 people viewed this tip
David Payne
David Payne
