Tip & How-To about Electronics - Others
Faulty USB Flash Drives
FAULTY FLASH DRIVES
Sometimes when a flash memory stick or USB external hard drive fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory USB hard drive device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the flash or external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs also between XP/Vista and earlier versions of Windows).
Otherwise format the USB flash drive in NTFS.
Insert the flash or external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Many people still don't realize this, but flash memory wears out the more you delete and write files to it. How quickly it wears out will depend on the specific flash drive. Like anything, there is a wide range of quality in currently available flash memory-based drives. You can make a rough correlation with the cost/quality of the device (what you pay is what you get), but even that tends to change over time. Depending on usage and quality it could be talking as short as months or as long as several years. In extreme cases of misuse it could lasting as little as a few weeks.
Electronics - Others Logo
sir i have 2GB pen drive it's not be formet window show formet is not complete. i need solution pls
If your computer affected by virus will not show in the pc .so you will install it to another pc,and format it .Flash drive can not recocknize,becayse there are some reason .
  • VIrus affected
  • Sometimes when a flash memory stick or USB external hard drive fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory USB hard drive device appears to malfunction it may be possible to restore it by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted then it will indicate that it is Healthy.
If this doesn't work then it is faulty.
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
hope it will help you
Feb 19, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
When i plug in the u3 flash drive it says usb device not recognized
Hi ,dkjran,
  • VIrus affected
Dec 12, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
usb storagedevicerepair
Jan 04, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
my memory stick pro-hg duo just stopped working all of a sudden for no apparent reason, it can't be recognized by any of the devices i have that support it, is there a way i can repair it
Dec 21, 2009 | Sony Electronics - Others
When I put my DaneElec 4GB USB Drive into my USB port, nothing happens. We have Vista.
Do other USB devices work when you plug them in the USB port?
If they don't then you have a faulty USB port otherwise the DaneElec is faulty or needs formatting.
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Oct 18, 2009 | Dane-Elec DaneElec 4GB USB Drive Copper...
4,944 people viewed this tip
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
