Tip & How-To about Refrigerators
Get those hard to clean condencer coils clean
Can't get your brush in to clean the condencer on your fridge, tape the big end of a funnel to your shop vac on blow or your electric leaf blower. you might want to do it outside though!!! it works really good if you dont have a compressor.
Refrigerators Logo
Toro model 51575. Was using it as a vacuum and it just shut off. Checked breakers ...all ok. Plugged it in direct to outlet and still nothing. What might be the problem?
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers
Apr 06, 2014 | Toro Blowers Rake and Vac - Electric...
Motor was losing power and burning
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Jan 13, 2014 | Toro "Toro" Super Blower/Vac
Where can I find brushes for my Toro electric leaf blower (model 51587)? I went to the Toro site and to Partstree.com, but they only sell the motor as a unit (which costs more than a new blower). A friend tells me I can buy any brushes for my electric leaf blower that are a little larger than the originals and just shave them down to fit, true or false?
Toro replacements are hard to find because Toro does not sell them and it is tricky to make you own.
Jun 07, 2010 | Toro Blowers Rake and Vac - Electric...
CONSTANT HUMMING SOUND COMINFROM THE REFIRGIRATOR.
is it comming from the duct in the upper left corner or the bottom press a dowel or rod of some kind on the duct and your ear and then the bottom,of the noise is comming from up top the damper motor is probly bad.if down low the compressor is under there and may be running hot turn off the frige then unplug it remove the lower back pannel and clean the condencer coil it's on the left side it's silender shaped metal rods. i tape the big end of a funnel to my shop vac and put it on blow this is messy but gets it good and clean good luck
Dec 08, 2009 | GE GSS22IFP Side by Side Refrigerator
motor on mod 51591 died, nedd replacement
The Mamco motor is WAY too much money.I bought brushes on E Bay and made them fit. #51591 takes 1/4 " square brushes.
Nov 28, 2009 | Toro Blowers Rake and Vac - Electric...
141 people viewed this tip
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
