Tip & How-To about Televison & Video
Samsung Color Wheel replacement!
This varies a little depending on model number of the set.
Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some sets may actually shut down if the wheel is bad or shattered.
To determine if you have a bad color wheel:
  1. Turn set off and wait for main fan to shut off.
  2. Unplug the set.
  3. Remove the lamp door and then remove the lamp.
  4. In the direction the lamp faces you will see a round opening; the color wheel is facing this opening. It is a round plastic wheel with colored segments—we want to look to see if any of the segments are missing; a shattered wheel should be clear to see.
  5. If the wheel is shattered or makes the high pitched fan like sound you can with the model number go online to someplace like Ebay with the model number of your set and find a part number and replacement wheel for your set---most of these are 70 to 90 plus shipping—make sure you get the right part.
  6. The wheel turns at about 14,000 rpm and eventually the motor seizes up causing this problem.
  7. Depending on model number there are some variations on how to replace it; but for the most part it requires the following.
  8. With the set unplugged remove the entire back cover.
  9. Locate the optical light engine dead center in the middle of the set. Some models have a large square box in front of it that you have to unbolt and remove plugs from one side—mark the plugs so when you remove them you can put them back in the exact same place.
  10. The Light engine has to be pulled out of the set to replace the color wheel; this kind of repair usually takes less than an hour from start to finish.
  11. Once you get the engine out you will find a somewhat square black plastic shroud on the right side of it----3 philips screws secure it to the frame of the engine.
  12. Remove the screws and you should be able to pull the shroud up and away.
  13. The Color wheel has two cables coming out of it; one is a 3 or 4 wire small square plug and the other is a flat ribbon cable. Be very careful when you remove the plug with wires—some people break the wires and then have to get the plug out of the socket with care. Both plugs connect the color wheel to the optical engine. The flat orange ribbon cable only has contacts on one side-WHEN YOU REMOVE IT NOTE WHICH DIRECTION THE CONTACTS ARE ON---if you put it in backwards(it can be done) the lamp will not turn on.
  14. You need to be careful when you replace the shroud over the color wheel so that the two cables(the ribbon cable and the other one) do not get pinched by it.
  15. With the wheel replaced; install the light engine back in place.
  16. All these sets have a safety switch on the back edge of the frame---it is a lever that will not allow the set to be turned on with the back removed. After you have installed the light engine back if you want to see if it worked; tape or hold the lever(usually blue and on the right side as you look from the back).
  17. If the set comes on and the lamp comes on do not look directly at the lamp---Once you see you have a working set turn it off and wait for the lamp fan to shut off in back—usually a few minutes.
  18. Bolt everything back and replace the back cover also---this should complete the repair.
  19. Some of these sets after you do this will work but the color will look off--flesh tones will be off--if this happens there is a small jumper on the metal box on the light engine that needs to be located and pulled out--places that sell the color wheel do not tell people about this. SD TECH
Televison & Video Logo
HLP4663wx/xaa Fan or Color wheel making noise? I first noticed it within the last week making noise when turning the set off. Now it's continuous. Could hear it slowing down on power off, constant speed now. Thanks
A fan like noise is 98% of the time the color wheel.
Wheel turns at over 12,000 rpm and common failure is "fan like sound or even grinding sound".
When these sets first came out if the high pitched sound started women who have better hearing in that range usually hear it first.
If wheel really fails it will shatter and set will not come on----a grinding sound may be noticed just before total failure.
SD TECH
Oct 17, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
will not turn on, hear a noise like something is turning
If the model number posted is correct it may be a color wheel.
see attached photo and remove lamp unit as wheel faces it.
Are any segments broken or missing on the wheel?
If wheel is shattered or not moving correct speed set will not fire lamp or work.
Usually a high pitched whine or even a grinding sound is a dead give away it is the wheel.
Let me know and this information is based on the model number posted
SD TECH
Oct 13, 2011 | Samsung HLN5065W 50" Rear Projection...
hlp4663wx/xaa loud buzzing sound and the tv shuts its self off and the
  2. Unplug the set.
  11. Once you get the engine out you will find a somewhat square black plastic shroud on the right side of it----3 philips2_bing.gif screws secure it to the frame of the engine.
  13. The Color wheel has two cables coming out of it; one is a 3 or 4 wire small square plug and the other is a flat ribbon cable2_bing.gif. Be very careful when you remove the plug with wires—some people break the wires and then have to get the plug out of the socket with care. Both plugs connect the color wheel to the optical engine. The flat orange ribbon cable only has contacts on one side-WHEN YOU REMOVE IT NOTE WHICH DIRECTION THE CONTACTS ARE ON---if you put it in backwards(it can be done) the lamp will not turn on.
BY THE WAY--THERE ARE ALSO SEVERAL SITES ON THE INTERNET WITH WRITTEN AND VIDEO INSTRUCTIONS FOR REPLACING THIS PART!
If this helped you rate this solution as I do this here for free. SD TECH
Dec 19, 2009 | Samsung DLP HL-P5663W 56" TV
howdoireplacecolorwheel??samsunghlp6163w
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Samsung Color Wheel replacement
This varies a little depending on model number of set.
  2. Unplug the set.
ALSO IF YOU GOOGLE YOUR MODEL NUMBER WITH COLOR WHEEL REPLACEMENT after it there are several sites with written and video instructions for this repair.
If this has helped you rate this solution as I do this here for free.
SD TECH
Dec 18, 2009 | Samsung HL-P6163W 61" TV
472 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
