Tip & How-To about Heating & Cooling
The extra benefit of a Modulating Boiler
You're looking to install a new hot water boiler or replace your existing boiler. You come across something called a "modulating" boiler. You wonder what on earth that means. I will attempt to explain some of the features of a modulating boiler.
How nice would it be if you could have your boiler make just enough heat to keep your house warm and nothing more? Your thermostat tells your boiler that you need heat in the house. The boiler starts up and heats the water that runs through the pipes to heat your house. The water does not heat up to temperatures that are more than just warm. But you notice that the temperature in your house is staying right where you want it to be.
This boiler is no ordinary boiler. It knows what the temperature is outside and varies your water temperature to make just the heat needed to keep you comfortable. The modulating boiler also runs much more then a normal boiler would but you can see by your gas bill that you are getting great efficiency from this thing.
The feature that makes this wonder so great is that it has the ability to vary the fire that heats the water up and down so that the water temperature stays precisely where the computer brain in the boiler wants it to be. This temperature is figured by measuring the outdoor temperature and changing the water temperature based on that. The colder the weather is outside, the hotter the water is going through your system.
With a system like this you will notice that your heat will run longer and still not cost anymore money. This makes you more comfortable. The modulating boiler will give you just enough heat to keep you warm without wasting much of the heat that a normal boiler would. This type of furnace will give you the most efficient heating possible on any given day.
Before buying a new heating system or replacing your old hot water boiler make sure that you check into a system that will modulate the fire and also vary your heating water temperatures according to the outdoor temperatures. This will save you money and give you a very comfortable heating system.
Heating & Cooling Logo
New Vaillant 360 eco plus boiler, takes almost 3/4s an hour for rads to come up to a decent temp. Hot water is fine. Called out install Engineer who is an excellent tradesman but he says everything
We have just had our old system boiler replaced with a vaillant ecotec plus 837 and sounds like a similar working operation to ours. At first I was a little concerned,but I was told by our installer that he was told by vaillant that these very latest boilers size the system on start up for about 10 mins, then take temperature to target flow which you set boiler at. So even by setting target flow temperature very high you still get the initial sizing cycle, which ours was about 30-35c temp. These boilers seem to run biased for efficiency as after a while they modulate the boiler burner down and the radiators run more on the side of warm than really hot like the old type boilers. You also get better efficiency as at lower temperature the boiler condenses better. You will also find you get a more constant temperature in your home rather than over shoots. I was concerned at first, shame there was no info/explanation in user manual as people do need to know that this is normal operation. We are used to ours now, took a month and by the way these boilers can make a creaking noise but was told this normal expansion/ contraction but annoying when sited in bedroom cupboard. Best of luck!
Oct 27, 2012 | Water Heaters
armitrol boiler mate hot water maker has code er3 and we have not hot water. can u tell us what that code means?
It tells you that your water heater called for heat for more than an hr and never got hot enough to meet the demand. multiple scenarios can cause this
CAUSES
-bad sensors
-no hot water from boiler
-bad thermal transfer
-low delta T across water heater
Dec 02, 2010 | Amtrol ST-120V-C THERM-X-TROL ASME...
354 people viewed this tip
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
