Tip & How-To about Heating & Cooling
Boiler Aquastat - How to set it
It is the coldest day of the year and your boiler is chugging along. However you notice that your house is slowly cooling off even though the boiler is running. Then you notice that the boiler is shutting down even though your house is not up to the thermostat temperature setting.
You look into the situation farther and notice that you boiler temperature is below say 180F. What is shutting the boiler off? The device that controls the temperature of your boiler is called an aquastat. This device senses the temperature of the water in your boiler, and then fires the burners to keep the water at the temperature call for by the aquastat.
The other role that this device may play is to keep the boiler from getting too hot and making steam. However for this time we will concentrate on the lower side and the heat of the water. If you have a house that has barely enough baseboard or radiators for that really cold day then you need your water to be very hot or around 200F. This will give the water enough BTU's to carry around the piping to give off to keep your house warm. The downside is that it also makes your boiler less efficient when it needs to heat the water this hot.
So, now you know that if you need more heat you can turn the aquastat up higher to get more heat and turn it lower on the milder days to save energy. Another way to do this is to buy and install a smart control that will do that automatically for you. These are called an outdoor reset control and will vary your boiler temperature according to the outdoor temperature, saving you money and keeping you warm all at the same time.
Now, the one thing you need to know yet. The aquastat is usually a gray box with a screw driver slot in a little wheel that has numbers on it. It is often hidden pretty well and may take some looking to find it. Some of the newer boilers may have a digital one that is in a bigger gray box. Read the instructions to learn to change the temperatures.
Setting your aquastat correctly can save a lot of money and it can be the difference between keeping you warm or not.
Heating & Cooling Logo
sea doo troubleshooting
check the fuel for water or blocked filter . check that the fuel tank is venting properly
Aug 16, 2014 | Cars & Trucks
I have a GMNT080 4B furnace this is the third season of use.I have had to replace the igniter 2 years ago.Now on start ups new this season it always has a noticeable explosion.Can be heard thruout the whole house.I also know a friend who is also having the same problem with a goodman unit 2years old.Pressures check normal.Would relocating the igniter help?
The modern boiler or furnace requires the exhaust fan to start first and then the igniter and the gas. As a boiler ages it seems to develop a "late" igniter though this usually results in a whoomph sort of noise that causes no trouble.
If the igniter is so late it causes an explosion it cannot be good and is potentially dangerous and probably damaging to the boiler.. It might help to move the igniter closer to the gas jets but it would be better to entrust this most important and safety sensitive adjustment to a qualified engineer who would be properly insured and who would have to take responsibility for the quality of the repair.
Sep 30, 2017 | Heating & Cooling
My 9 year old side by side is not cooling properly even though set on coldest setting, water is leaking from bottom of freezer door and ice has condensed on the back of the freezer section. Is it worth repairing?
Hi! Do you notice any bubbles from the units wall? If there is then the problem will be internal. Assuming the motor is working but the cause will be inside the walling. If you call for repair guys they will ask you that it will be tested but you have to pay the diagnostic price knowing that its unrepairable. I suggest that going for a new one will be greater. Hope this helps and have a good one!
Jul 17, 2010 | GE Refrigerators
exhaust emission light Golf 1.6 S 2001
when the engine light flashes its telling you the car is miss firing and from your description it was...even though you had coil packs replaced that is by far the most likley cause .if they were genuine parts you will have unlimited milage 2 year warranty.get the fault code read to find out what cylider the misfire was on and change that coil pack..
Feb 19, 2009 | 2001 Volkswagen Golf
2,352 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
