Tip & How-To about Cell Phones
How to make your bluetooth cellular phone into a universal PC remote controller
Control i Tunes, PowerPoint, Mouse, Win AMP, Windows Media Player and much more
- Just go to Blue tooth remote control in your phone then check all the applications
- Create your own applications via Key maps or VB and Scripts
- Supports all PC Bluetooth solutions Toshiba, Windows, BlueSoleil and Widcomm/Brodacom
Cell Phones Logo
Remote code for sony blue ray player
There is no set-up code to any brand blue-ray player with this remote control.
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Aug 21, 2014 | RCA Televison & Video
xvid for windows vista
I've spent a lot of time this weekend finally setting up Windows Vista Media Center, and I suddenly realised that Vista Media Center won't play Xvid and Avi files even if Windows Media Player will. If you want to add support for third party codecs including Xvid and Avi files in Vista Media Center then you need to install the Media Control Plugin For Windows Vista Media Center.
This plugin allows Windows Vista Media Center to utilize te FFDShow decoder, which needs to be installed seperately ((FFDShow rev 1108 recommended: download the last version from http://sourceforge.net/projects/ffdshow-tryout)). FFDShow adds support to Vista for MPEG-4 video formats like DivX, Xvid, H.264 and also alllows MP3, AAC, Dolby AC3, and OGG Vorbis audio files to be played back.
The Media Control Plugin for Windows Vista MCE also adds the following additional features:
  • Switching embedded audio and subtitles streams while playing a video: works with AVI, OGM, MKV
  • Switching between external subtitle files (.SRT, .SUB)
  • Switching between FFDShow presets (audio & video)
  • Setting and loading bookmarks inside a video with visualization of the pictures of the saved bookmarks
  • Real fastforward (and rewind) exactly like in the TV module (with 3 different speeds)
  • Switching and setting post-processing filters in FFDShow (video filters only)
  • Separate application to assign keyboard/remote control shortcuts to the commands and the MCML pages of the plugin.
  • Full remote control support (6 buttons are mapped by default, but this can be changed)
  • Default mapping (works in full screen while watching a video, except the blue button that is always caught) :
    • Fast forward / rewind buttons
    • Blue button : loads the startup page of the plugin
    • Red button : switches audio stream
    • Green button : switches subtitle stream
    • Yellow button : switches subtitle file
May 06, 2011 | Dell Computers & Internet
How to add remote control (connecting via Bluetooth/Infra-red) for a laptop to play Media player?
http://www.retrevo.com/s/SMK-Link-VP6600-Universal-Remotes-review-manual/id/2881bh146/t/1-2/
this is the blue-tooth solution ..it is a remote for the player via blue-tooth ..its charges on the card slot ..and last up to one week
Or if your cell phone supports ..some models can be used to remote control the laptop via bluetooth ..usually all you have to do is install the feature in the phone..
o r..this is a infrared one ..
using a usb connection ..
http://compare.ebay.com/like/140411021885?ltyp=AllFixedPriceItemTypes&var=sbar&afsrc=1
Jan 20, 2011 | Computers & Internet
blue tooth icon missing from system tray now Dell blue tooth mouse wont work
You need to connect a wired usb mouse first and try pairing the bluetooth mouse again with your system by going to the control panel and opening your bluetooth device manager. Click add a device and press the connect button underneath your mouse. System should be able to detect your mouse. If that failed, try replacing the batteries with fresh ones.
May 24, 2010 | Dell Studio 17 Laptop
Hitachi cp-s240 remote question
Hitachi data projectors are able to function as a mouse using either the USB port or the control port located on the back of the projector.
However, they are not intended to be used as a remote presenter. This means that although you can use the remote as a mouse, you will not be able to change slides in a full screen slide show using powerpoint.
I recommend the Targus remote presenter for this purpose. This device will function as a mouse, pointing device, and will allow you to change slides in powerpoint. In addition, it's inexpensive, wireless, and small enough to easily fit in your pocket.
Mar 02, 2010 | Hitachi CP-S240 Multimedia Projector
187 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
