Tip & How-To about Heating & Cooling
Carbon Monoxide and Heating Systems
Every year there are many deaths that could be avoided by a few simple checks, or the addition of a carbon monoxide detector in the home. The worst thing is that many of those people will have never known that they were under attack by a silent killer.
One of the products of the combustion of any fuel is carbon monoxide gas. The concentration of this gas can vary greatly depending on how complete the combustion process is. Many heating systems will check the combustion process and shut themselves down if the flame becomes too unstable and begins to produce harmful gases. There also are many heating systems still in service that do not check and will produce carbon monoxide gases. If carbon monoxide gas can get into your living environment then you and your family could be at risk.
To reduce the risk of carbon monoxide gas affecting your home, you should have your furnace checked every year. Make sure that the venting system of the furnace or boiler is in good condition. Make sure that the safety controls work properly and are not bypassed. Never bypass the safety controls to get heat even temporarily. Make sure that if you are using an unvented appliance in your home that you follow the instructions by opening a window a bit to give the heater fresh air. Many of these appliances have a oxygen sensor in them to protect you. Make sure to clean this device yearly and if the heater keeps going out and you don't know why, it could be because of oxygen depletion in the room.
Plugged chimneys, bad vent piping, wrong gas pressures, faulty, dirty burners, and many other things can cause carbon monoxide to build up in your home. Be careful to have all of these things checked often. If you heating system is not acting right then you need to have it checked immediately.
One of your best defenses against carbon monoxide is a detector. I like the ones that actually give you a digital read out of the level of the harmful gas in your home. You will find that even your gas range or oven will produce carbon monoxide and it is helpful to see when even low levels occur. The other reason is because the detectors that only give a warning on high levels will often not warn you till the gas reaches deadly levels. You want to be aware of these levels long before the reach deadly levels. This gives you time to get a problem identified and fixed. Also time to evacuate if necessary.
For best peace of mind, spend the money to buy a good quality carbon monoxide detector and then make sure you get it out of the bag and install it. Get your heating system serviced by a professional that can check the combustion process to make sure your heating system is burning cleanly and efficiently. By doing a few simple things you can protect yourself and the ones you love.
Heating & Cooling Logo
I cook a lot and my mother thinks I should get a carbon monoxide detector. Is it really necessary?
If you are cooking a lot, especially using an oven it is really important to have a carbon monoxide detector. You'd be surprised at how many CM related deaths there are a year because people don't equip their homes with one.
Jan 10, 2013 | Home
How can I shut off my Kidde carbon monoxide detector when beeping
Here is the link to the manual for your Kidde model KN-COB-LCB-A
Carbon Monoxide Detector. This may help you solve your issue.
You may find more related information on my website. If you need a replacement or you need to add additional Carbon Monoxide Detectors in other levels of your house, you can purchase them here.
This issue should be solved immediately, Carbon Monoxide Poisoning can only be avoided by making sure you have good working CO Detectors in your house, camp or recreational vehicle.
Jul 24, 2010 | Kidde Nighthawk Combo Gas/co Detector
My nighthawk Kidde carbon monoxide detector keeps beeping every 25-30 seconds. Do I need to buy a new one?
Some models of Carbon Monoxide Detectors will give an audible beep every 25-30 seconds after it has sounded an alert alarm. This may have happened when there was noone home to hear it. A periodic beeping sound may also indicate it is time to change the battery.
Solution: Install a new battery and check your manual for instructions on how to reset the system. Check the expiry date on your unit, it needs to be replaced after 5 to 7 years, according to the manufacturer specifications.
If you are in doubt that your Carbon Monoxide Detector is not working effectively, REPLACE IT. Your safety and your peace of mind is worth it.
View most Brands and Models of Carbon Monoxide Detectors online.
Jun 27, 2010 | Kidde Nighthawk Combo Gas/co Detector
Nighthawk Combo Gas/co Detector: is 218 a high read of carbon monoxide levels in a ...
A reading of 218 should be treated as an emergency. When a Carbon Monoxide level reaches over 70 ppm, you should have a professional inspect and repair the appliance that is causing this issue.
Carbon monoxide levels above 70 ppm will cause headache, fatigue and nausea. Levels above 150 ppm can cause serious injury or death.
Read section 5 US Consumer Product Safety Commission.
May 17, 2010 | Kidde Nighthawk Combo Gas/co Detector
lost manual for the nighthawk carbon monoxide detector, model no.900-0082-00 made in 11/1996. hasnt been used for several years.DON'T KNOW HOW TO SET IT.
Hold on!
All carbon monoxide detectors have to be replaced after 5 years of manufacture date. The sensors are not reliable after that time and may give false readings.
A carbon monoxide detector is your only defense against the hazards of Carbon Monoxide Poisoning. I would never recommend installing a used Detector. Ask your local fire department for more professional advice on how and where you should install carbon monoxide detectors.
Visit my website for more information. Buy your next Carbon Monoxide Detector here.
Aug 13, 2009 | Kidde Low-Profile Digital AC Wire-In...
810 people viewed this tip
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
