Tip & How-To about Microsoft Xbox 360 Console
Xbox 360 x clamp mod
Find a tutorial on how to diasembel your xbox on youtube .
now with all screws removed including the 8 small black ones
remove the lid , you will need to lift the edject button out of
the way to get the lid off .
lift the drive out pull out the two plugs conecting the ROM drive
and set it aside .now pull off the white cover on the power button
there are three small black screws under it take them out and
pull the power button P.C . board out
take a thin straght head screw drive and pop the
Microsoft Xbox 360 Console Logo
how do I replace keyboard on Gateway EG70
Keyboards are easy to change in most laptops, just be easy when installing the new one... don't press any keys down at an odd angle or the keypads will come off! You will need a precision screw driver set... usually used to service watches and small electronics. Tiger Direct sells them. Nothing fancy, run about $8. The parts manual for your PC or laptop with have the schematic which shows you the parts, study it carefully to determine which screws hold the pieces to remove the bezel that surounds the upper part of the keyboard, just under the screen. There are a few small screws there. The keyboard in then extracted towards the screen and an angle, disconnect the ribbon connector for it as soon as you can get a little access to remove it. It just slides out with a little pressure, don't tug on the ribbon cable or you can break the connector. Put the new one in the reverse order and replace the bezel.
Feb 27, 2015 | Gateway Computers & Internet
was playing black opps on my 360 and it randomly shut off. restarted it and it worked for about 25 mins then the red rind of death showed ujp. now what?
mine did the same thing. Found a tutorial on YouTube that walks you through the entire fix process. You have to break your xbox 360 down to the mother board and replace the x-clamps with different screws and washers. If you find the right tutorial it will tell you exactly what screws, washers and tools you need. Search youtube for "How to fix Red Ring of Death".... dig through all the tutorials till you find the one that best suites your knowledge of your xbox. As for me, I needed the step by step from breaking it down to putting it all back together. Also watch the entire video first, I broke a few pieces of plastic before watching how to take it apart. Hope this helps. It helped me.
Jan 31, 2011 | Microsoft Xbox 360 Console
Need to replace the lid switch and how to get to it. Do we need to completely remove the casing? Then how to replace the lid switch?
Good day,
Yes, the whole cabinet needs to be removed. The whole front sides, and top are actually one piece, although it oesn'r look like it.
Your first step is to rotate the console out of the way. Be aware the 2 screws that hold it in place can be either on both bottom corners, on both bottom corners but with end caps that have to be unsnapped first, and lastly on both back corners.
Here's a tutorial on disassembling.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
May 25, 2010 | Kenmore Washing Machines
413 people viewed this tip
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
