Tip & How-To about Computers & Internet
How to Decrease Menu Show Delay Time in Windows Operating Systems.
Go to Start--> Run and type "regedit" without quotes, Then Registry Editor will open, Navigate to HKEY_CURRENT_USER--->Control Panel---> Desktop. Look to right pane and search for "MenuShowDelay", Change the value (default=400) by modifying it to "10". Then restart your computer and you can find the Start Menu items accessible very fast.
Computers & Internet Logo
Logon Change
Enable Log-On Screen
Windows, by default, is set to show the Welcome screen during startup.
To enable the log-on screen to show, go to "Start" menu and select "Control Panel".
In the control panel, click on "User Accounts".
In the "User Accounts" dialog-box, click "Change the way users log on or off" and uncheck the "Welcome Screen" option.
Click "Apply Options" to save the changes.
Change Log-On Screen Background Color
To change the log-on screen background color, go to the "Start" menu and click on "Run".
In the run dialog-box, type "mspaint" as the name of the program to "Open".
Click on "OK". In the "Paint" window that opens, select "Colors" from the main menu and click on "Edit Colors". In the "Edit Colors" dialog-box, select "Define custom colors".
Here pick the color of your choice and note down the "Red", "Green" and "Blue" values.
Write down these values somewhere.
Click "Cancel" and close the paint window without saving. Now, go to the "Start" menu, click "Run" and enter "regedit" as the name of the program to "Open".
In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\COLORS and double-click the "Background" string.
In the "Edit String" dialog-box that opens up, change the values in the "Value data" field to the red, green and blue color values that you wrote down (e.g. 75 78 173).
The default value will be 0 78 152. Enter the values in the correct red-green-blue order, separated by a space. Close the registry editor and log off to see the changes.
Put Image in Log-On Screen Background
To put your favorite picture in the background of the log-on screen, click "Start", then "Run", and type in "regedit". In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\DESKTOP and double-click the string "Wallpaper". In the "Edit String" dialog-box that opens up, enter the full path and filename of the image that you want to use as the background. The image must be in .bmp format. Click "OK" and close the registry editor. Log off to see the changes. hope this helps
Oct 03, 2012 | Microsoft Windows XP Home Edition for PC
When installing Norton Ghost 15.0 onto a XP machine I get the following error message. "Error 1606. Could not access network location 0\."
This is a fairly common problem in Windows XP, especially with SP2. The most common method that fixes it is to delete some registry keys.
Click on Start-Run, type regedit (without the quotes) Navigate to this registry path:
HKEY_CURRENT_USER --> Software --> Microsoft --> Windows --> Current Version --> Explorer --> User Shell Folders
Clear the key: Recent (right mouse click on the key/folder, choose Delete) Close the Registry Editor and restart the computer.
Apr 15, 2011 | Symantec Norton Ghost 14.0: Windows
how i can reuse the norton 360 v 4.3.0.5 Its trial period is expired. Plz send me product key or trial reseter. special thanks
Please remove the existing version of Norton program from the control panel, then go ahead and delete all Symantec and Norton files from the computer's C or D drive.
After that, open your registry and first take a back up just in case anything get deleted by mistake.
Then delete all Norton and Symantec files from HK CURRENT USER, HKEY LOCAL MACHINE, HKEY USERS, HKEY CURRENT CONFIG.
You can click on the SOFTWARE folder in each class to find the Norton files if any.
To open your registry editor, type regedit in RUN command (windows key+R)
After that you can again install a trial version of Norton for 30 days.
Feb 05, 2011 | Symantec Norton 360 Full Version for PC...
error1606
These are the fixes for that error that I am familiar with...The first one usually does it.
Click on “Start-Run, type “regedit” (without the quotes) Navigate to this registry path:
Clear the key: Recent (right mouse click on the key/folder, choose “Delete”) Close the Registry Editor and restart the computer.
Or …. “Error 1606. Could Not Access Network Location <Common Administrative Tools>.All Users\'' Error Message When You Install a Program”
http://support.microsoft.com/default.aspx?scid=kb;en-us;Q315352
Or….”Error Message When You Install Plus! for Windows XP: ''Error 1606. Could Not Access Network Location''
http://support.microsoft.com/default.aspx?scid=kb;en-us;Q307683
From (Grif Thomas)
Feb 03, 2010 | HP PC Desktop
how to enable control panael,taskmanager
Method 1 - Using the Group Policy Editor in Windows XP Professional
  1. Click Start, Run, type gpedit.msc and click OK.
  2. Under User Configuration, Click on the plus (+) next to Administrative Templates
  3. Click on the plus (+) next tSystem, then click on Ctrl+Alt+Delete Options
  4. Find Remove Task Manager in the right-hand pane and double click on it
  5. Choose the option "Not Configured" and click Ok.
  6. Close the Group Policy Window
Method 2: Change the Task Manager Option through the Run line
  1. Click on Start, Run and type the following command exactly and press Enter
REG add HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System /v DisableTaskMgr /t REG_DWORD /d 0 /f
Method 3: Change Task Manager through a Registry REG file
  1. Click on Start, Run, and type Notepad and press Enter
  2. Copy and paste the information between the dotted lines into Notepad and save it to your desktop as taskmanager.reg
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"DisableTaskMgr"=dword:00000000
3. Double click on the taskmanager.reg file to enter the information into the Windows registry
Method 4: Delete the restriction in the registry manually
  1. Click on Start, Run, and type REGEDIT and press Enter
  2. Navigate to the following branch
    HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Policies\ System
  3. In the right pane, find and delete the value named DisableTaskMgr
  4. Close the registry editor
For Control Panel
Start | Run | Type: gpedit.msc | OK |
Navigate to >>>
User Configuration\Administrative Templates\Control Panel\
Prohibit access to the Control Panel
[[Disables all Control Panel programs.]]
Jan 12, 2010 | Microsoft Windows XP Home Edition
429 people viewed this tip
David Payne
David Payne
