Tip & How-To about Computers & Internet
How to Install Window XP with Vista
If you wish to install Windows XP on a computer that comes with Windows Vista already installed then you will have to create a separate partition on your hard drive to install Windows XP onto. This effectively splits the hard drive into two, and keeps the different versions of Windows separate. To do this you need to open up the Computer Management screen by going to the Start menu and then right-clicking on Computer and selecting Manage.
From the Computer Management screen select Disk Management, right-click on your main hard disk where Windows Vista is installed and then select Shrink Volume. This opens up a window where you can choose how large you want the new drive partition for Windows XP to be. You need to select the size of the new partition carefully, as you will need enough space to be able to install Windows XP successfully (around 10 gigabytes) whilst leaving enough space for Windows Vista. After you have selected the appropriate amount of space click on the Shrink button to begin the process, and once that has completed you should be able to right-click on the new partition (which should be labelled “Unallocated free space”) and select New Simple Volume.
Follow the on-screen instructions to configure the partition, set a drive letter (such as E:\), give it a meaningful name such as “XP”, and then restart your computer. Whilst your computer reboots, access the BIOS and change to boot sequence to boot from your CD/DVD Drive before any other device, insert your Windows XP installation disc and then save and exit from BIOS. You will then be taken to the Windows XP installation program where you should follow the instructions until you come to the screen asking you which partition to install Windows XP to.
Make sure you select the new partition and not the one with Windows Vista installed, as this will cause problems. Once Windows XP has finished installing, you will notice that Windows XP loads up automatically, rather than giving you the choice of which operating system to use. To rectify this insert your Windows Vista installation disc and restart the computer to access the Windows Vista installation program. From the Install Now screen select Repair My Computer, and then select your Windows Vista installation and then Startup Repair. You will now be able to choose which operating system to use when your computer starts up.
Computers & Internet Logo
Acer 3690-2710 Laptop: I currently have Windows Vista but I also like to install Windows XP. Is it possible? I tried and message came up that not compatible.
Yes this is completely possible in two ways.
(1) You can install both of these Operating systems Vista ans XP on one PC and when one boots the other is not cannot be booted unless you shut down the first one. Only one OS will run at a time.
(2)You can run XP inside Windows Vista. I have not yet tried vice versa but I find no reason why it is not possible. Remember that you will be running Windows Vista and you will be running Windows XP in a Window with full functionality. You have to use a technology called Visualization. One of the software that facilitates this is called Virtual PC 2007 by Microsoft and it is not difficult to use once you have the basic knowledge. With this software you have to create something called a Virtual machine of Windows XP.
When you install XP and Vista, such as I described in option (1) above, y ou have to divide your hard disk into two parts called partitions and there are labeled as C:, D:, E: etc to distinguish from each other. If you have already installed Vista in one partition usually C: partition you install Windows XP on the other partition. If you have only one partition then you have to create an additional partition to install Windows XP otherwise the message of "not compatible" will be displayed. Remember that you cannot install two operating systems on a single Hard Disk with a single partition on it. You have to break the hard disk down into partitions and install the Windows Vista and XP one by one. You can easily create partitions using the partition software like "Partition Magic".
Since at this point I do not know which option you would like to pursue from (1) and (2) therefore I cannot guide you any further and wish you
Good Luck!
Sep 15, 2010 | Computers & Internet
how do i remove windows vista and install windows xp with out losing all my other stuff
If your Vista still work, go to the control panel> administrative tools> computer management > disk management > create an additional partition (larger then my documents folde size)
Move your files to this partition then install xp.
A few tips
  • Make sure there xp drivers for each componenet
  • Use driver magician and find xp drivers (check the pc mfg site and download all xp drivers and put them on this partiton too.
  • Use a partition program (dos) and format the vista partition and the hidden partition that vista creates or xp won't go in properly
Jan 24, 2010 | Microsoft Windows XP Home Edition
how to install XP in toshiba Satellite L45-S7423 laptop
You can access Vista disk management (right click on computer from the Start Menu > Manage > Storage > Disk Management) and shrink your current partition and create a new one. Then install XP on that new partition. This is if you want a dual boot of both XP and Vista.
Nov 17, 2008 | Computers & Internet
141 people viewed this tip
David Payne
David Payne
