Tip & How-To about Kitchen Appliances - Others
Replacing a Christmas light Bulb
Replacing a Bulb The ideal replacement is one from an identical "replacement" string bought at the same time as the "operating" string. Anything else is a much less desirable option. Many strings have two separate circuits of bulbs. Within each circuit, all the bulbs are wired in series. They each see the same small fraction of the line voltage, but only as long as the bulbs operate identically. Different strings can have bulbs of significantly different resistance, yet all bulbs will operate at the same voltage, as long as the bulbs are similar within a circuit. But if we place a high-resistance (typically dimmer) bulb in a generally low-resistance (typically brighter) circuit, that bulb can see far more voltage than it was designed to handle. In that situation, the bulb may simply burn out in a fraction of a second. Another issue seems to be warm-up time: All incandescent bulbs increase their resistance as they warm up. But even bulbs with the same ultimate operating voltage can warm up at different rates. And if a fast-warming bulb is placed in a slow-warming string, it can quickly see much more voltage than expected, and may blow out. It is much, much better to buy two strings to operate one string, and then use the other simply for replacement bulbs. But that requires prior planning. For existing strings, there may be an option: If two or more strings were bought at the same time, we can take one out of service, put it in a zip bag and use it for replacement bulbs. For existing lone strings, there still may be an option: Convert a 100-bulb string to a 50-bulb operating string and a 50-bulb dark replacement string. That can be as simple as taking bulbs as needed from one half of the string and using them in the other half. Of course, then we end up with half a string that looks like it desperately needs work. An alternative is to cut the string in the middle and end up with one fully-working short string plus a short string of replacement bulbs that we can keep in a bag. Typically, three wires are twisted together across most of a string, but only two are twisted at the start, middle, and end. So if we look for the two-wire section in the middle, we can cut there (after first turning the power off). On the working half, we can fold each of the two just-cut wires back upon itself and wrap each separately with tape, or separately insulate with electrical heat-shrink tubing.
Kitchen Appliances - Others Logo
Triangle and light bulb after replacing with new lamp
The board that connects to the lamp socket is called the ballast. It controls the lamp operation. The problem you have points to that board.
Jan 12, 2014 | Televison & Video
How to change a string? (My instrument is bought to day) Sincerely yours Herluf Sklibdahl
After getting the PROPER string, watch YouTube videos on replacing strings... guitar and mandolin are similar so you can watch either. Search "replacing string" and select video from choices.
Sep 05, 2011 | Fender Musical Instruments Corporation...
My homelite (the shrub sharper 21) pull string broke. I want to replace string. How do I replace new string.
Replacing a pull string on anything is a tricky operation, taking it apart is easy, but getting the springs back in place and everything wound up is not easy. I would suggest finding a local hardware store or equipment rental location, and find somebody to do it for you. I made the mistake of attempting to do it, and 3 hours later and a lifetimes worth of frustration later I got it. Save yourself the trouble and pass it off to somebody else.
May 17, 2011 | Garden
Replacing the bump head on homelite string trimmer
undo the 2 screws on top of the carb. The bulb is part of a 2 piece cap undo that and it fall out.
May 16, 2009 | Homelite Mighty Lite Lawn Trimmer
176 people viewed this tip
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
