Tip & How-To about Computers & Internet
How to create a system folder in My Computer System folder like My Document which appears in My computer are special folders which appear can not be deleted. Now if you want to create something like that, a folder which cannot be deleted!!!! . Here is how you do it to create a folder which cannot be deleted!!. It should work both in XP and VISTA.However a word of caution, If you don’t know about registry, either back up or don’t try this. I am not sure how to create a direct script for this so be cautious. Step 1: Create a Unique Key Open registry with “regedit” command on run window. Navigate to HKEY_CLASSES_ROOT\CLSID\. Then right click and create a new key with value as {FD4DF9E0-E3DE-11CE-BFCF-ABCD1DE12345} Now set the default value of this key to the folder name you want to use. Now your path will look like ( I will call this as parent key throughout the discussion) HKEY_CLASSES_ROOT\CLSID\{FD4DF9E0-E3DE-11CE-BFCF-ABCD1DE12345}   Step 2: Add Custom Icon to the folder Now create a sub key under parent key. Name it as “DefaultIcon”. Set the default value of this to the path of the icon image you want to use. If you dont specify your icon, system will take default icon. Step 3: Adding attributes Under parent key create another key with name as “InprocServer32′ Set the default value as “shell32.dll” Again at the same level create another folder as “ThreadingModel” and set its value as “Apartment” Same way create another key (under parent level) at the same level with structure as \Shell\My Folder\Command Set the default value here as “explorer /root,c:\Blog Data” This has to be same which you gave when you created the first key. Step 4 Adding Handlers Under parent key, create another key as \ShellEx\PropertySheetHandlers\ {FD4DF9E0-E3DE-11CE-BFCF-ABCD1DE12345} Similar way another key is to added to parent key as “Shell Folder” In this right click and create new binary value called as “Attributes” with value as 00 00 00 00. Step 5: Settings to place in My Computer Go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows Then to \CurrentVersion\Explorer\MyComputer\NameSpace\ Add the parent key which in this case is {FD4DF9E0-E3DE-11CE-BFCF-ABCD1DE12345}   Thats it, You are done. Try this carefully and I am sure there wont be any problem
Computers & Internet Logo
I want to create new folders from my documents in my computer how do I do it
get the desk top screen up
right click anywhere on a vacant patch that brings up a drop down box where you will see new folder
click on that and that folder appears on the desktop screen
rename it to suit what you want to call that folder
then when yo need a document saved -save to desktop and then move that file into the named folder
if you have documents already in say my documents click and hold and drag that file to the appropriate folder on desktop
if you have just the one monitor , get into the library area and open up my documents the drag each document to the folder in the library drop down area
Basic I know but with a bit of practice you will get to moving documents to folders very quickly
Aug 07, 2016 | Lenovo Computers & Internet
Trying to find driver download for digital camera PL-50 [A1-W4C98S488244Z. Cannot match criterium on your website Can't get match to allow download.
Windows will automatically install the software driver necessary to connect your camera to your PC. Here is the procedure for transferring the files.
To transfer images from your camera to your Windows XP PC, follow these steps:
  1. Connect your camera to your PC using the USB cable.
  2. namo_fileview.jsp?type=nfs&pid=decisiontree&did=144733&cid=m9wggrmgsfx4@namo.co.kr&sep=%7c
  3. Turn your camera on, your camera will connect instantly to your PC. If a message appears on your camera shown in the illustration below, select the 'Computer' option on your camera.
  4. namo_fileview.jsp?type=nfs&pid=decisiontree&did=144733&cid=a0xtcanr1rvt@namo.co.kr&sep=%7c
  5. After you have selected the computer option, a pop-up appears on your PC informing you that Windows has found new hardware.
  6. namo_fileview.jsp?type=nfs&pid=decisiontree&did=144733&cid=tuioa5ssuene@namo.co.kr&sep=%7c
  7. Double click the 'My Computer' icon located on your desktop. The My Computer window appears.
  8. namo_fileview.jsp?type=nfs&pid=decisiontree&did=144733&cid=to4yf37vh01w@namo.co.kr&sep=%7c
  9. Double click the 'Removable Disk' icon in the My Computer window. The Removable Disk window appears.
  10. namo_fileview.jsp?type=nfs&pid=decisiontree&did=144733&cid=c8lfz575xq3k@namo.co.kr&sep=%7c
    Note: The drive letter associated with the removable disk may be different depending on your system.
  11. Double click the folder names DCIM in the Removable Disk window.
  12. namo_fileview.jsp?type=nfs&pid=decisiontree&did=144733&cid=xzed4rdwasgk@namo.co.kr&sep=%7c
  13. Find the folder named 101SSCAM. The images taken with your camera are in the folder.
  14. namo_fileview.jsp?type=nfs&pid=decisiontree&did=144733&cid=mz3fxisgo75j@namo.co.kr&sep=%7c
    Note: Each folder in your camera contains up to 99 images. Once this limit is reached, your camera creates a new folder. Folder names may vary depending on your Camera's Series.
  15. To copy the entire folder to your PC, right click the 101SSCAM folder. A menu appears.
  16. Highlight 'Send To' in the middle of the menu. A sub menu appears.
  17. Select 'My Documents'.
  18. namo_fileview.jsp?type=nfs&pid=decisiontree&did=144733&cid=0rqvdovkfrzf@namo.co.kr&sep=%7c
  19. Windows copies the folder into 'My Documents'. Depending on how many photos are in the folder, copying may take a few minutes.
  20. Double click the folder in My Documents to access and view the pictures taken with your camera.
  21. namo_fileview.jsp?type=nfs&pid=decisiontree&did=144733&cid=3od76ibo8lji@namo.co.kr&sep=%7c
May 16, 2011 | Samsung Cameras
printer does not have a disc with it ,it was givin to me buy a friend is there a way to get it working ,hpdeskjet656c
you need to download the drivers for your printer.
Create a new folder on the hard drive: c:\dj656 before downloading the printer driver.
  1. Download the driver to the newly created c:\dj656 folder.
  2. Open the c:\dj656 folder and double-click the downloaded "exe" file.
  3. Under c:\dj656 folder a folder will be displayed. For example, "2kxpinf" will be displayed. This folder was created by double-clicking on the downloaded "exe" file.
  4. Power on your printer, and connect your printer to the computer with a USB cable.
  5. The "Found New Hardware Wizard" will appear.
  6. Choose "Install from a list or specific location (Advanced)"
  7. Click "Next"
  8. Click "Search for the best driver in these locations"
  9. Click "Include this location in the search"
  10. Click "Browse" and go to the folder, "c:\dj656\2kxpinf\enu\drivers\win2k_xp". Click "Ok" after you have browsed there.
  11. Click "Next"
  12. A dialog box will appear indicating the driver is being installed.
  13. To complete the installation process, click "Finish". The "hp deskjet 656c series" printer driver will be added to the "Printers" window.
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?lc=en&cc=us&softwareitem=dj659en
Oct 13, 2009 | Computers & Internet
i cant upload my pics to my computer
How To Transfer images To Your Windows XP/VISTA PC P, td, li {font-family: arial, u; font-size:9pt; margin-top:0px;margin-bottom:0px; word-spacing:1px;} To transfer images from your camera to your Windows XP PC, follow these steps:
  2. Turn your camera on, and then select the 'Computer' option on your camera.
  3. After you have selected the computer option, a pop-up appears on your PC informing you that Windows has found new hardware. Close the pop-up.
  4. Double click the 'My Computer' icon located on your desktop. The My Computer window appears.
  5. Double click the 'Removable Disk' icon in the My Computer window. The Removable Disk window appears.
  6. Double click the folder names DCIM in the Removable Disk window.
  7. Find the folder named 101SSCAM. The images taken with your camera are in the folder.
    Note: Each folder in your camera contains up to 99 images. Once this limit is reached in an existing folder, your camera creates a new folder. The folders are labeled successively: 102SSCAM, 103SSCAM, etc.
  8. To copy the entire folder to your PC, right click the 101SSCAM folder. A menu appears.
  9. Highlight 'Send To' in the middle of the menu. A sub menu appears.
  10. Select 'My Documents'.
  11. Windows copies the folder into 'My Documents'. Depending on how many photos are int he folder, copying may take a few minutes.
  12. Double click the 101SSCAM folder in My Documents to access and view the pictures taken with your camera.
How To Transfer images to Your Mac PC P, td, li {font-family: arial, u; font-size:9pt; margin-top:0px;margin-bottom:0px; word-spacing:1px;} To Transfer images from your camera to your Mac, follow these steps:
  1. Turn on your Mac, and then connect your camera to your Mac using the USB cable.
  2. Turn your camera on, and then select the Computer option on your camera's screen.
  3. An icon appears on your Mac desktop labeled Untitled.
  4. Shortly after, a pop-up appears on your Mac desktop. Click 'Download All' in the pop-up.
  5. After downloading is complete, another pop-up appears containing the pictures taken with your camera.
Dec 31, 2008 | Samsung L200 Digital Camera
delete RECYCLER folder
Right click the recycle bin in 'my computer' or on the desktop and goto the properties. You may then configure the recycle bin for each drive or turn it off altogether. Once it is turned off for a particular drive you may remove the recycler folder (ignore the warning) it will not re-appear again when you delete files.
Oct 02, 2007 | Microsoft Windows XP Professional With...
246 people viewed this tip
David Payne
David Payne
