Tip & How-To about Blenders
Trouble shooting problems with your starting system
When trouble shooting a problem with an electric started engine ie; a suspected faulty starter,solenoid,ignition switch etc. it is common to 'jump' the solenoid, this is done by connecting the two large wires at the solenoid , on most vehicles the solenoid is connected directly to the starter (its the smaller cylinder) however it is very common for ford to mount them on a inner fender, you can simply follow your positive wire coming out of the starter, it will lead first to the solenoid then finally to the positive battery terminal, the solenoind consist of three wires, two large ones and one much smaller, one of the large wires will lead to the positive battery terminal, the other large wire, directly into the starter , the small wire is the power supply to the solenoid (operated by your ignition switch) which is what engages to connect the two larger wires, if you jump the two large wires *(i commonly use a wrench or two screwdrivers whatever it takes , be carefull of the sparks, or loom yourself a switched wire for more safety)* the engine should turn over! it will not start unless you turn on the ignition... this is a simple way to 'bypass' the solenoid for trouble shooting purposes, this example i just used a week ago and determined that i will have to remove the starter for a closer inspection, as it was just replaced two weeks prior! in this case the starter was shot. more on that some other time.
Blenders Logo
diode in blender,what its function
Most of the time a diode is to reduce the amount of electricity to something.
For example. I had an electric train.
The transformer made it go too fast, and it would jump off the tracks. I added a diode between the transformer and one of the wires to the track wire connector, and reduced the electricity to the engine, hence it slowed down to 1/2 speed.
God bless your efforts.
Mar 28, 2017 | Blenders
how do i unlock the breville cbl25xl jug
Probably why it was got rid of. But if you have the manual check trouble shooting or contact manufacturer.
Dec 16, 2014 | Breville Blenders
ugolini slush machines
It will ne the thermostat for sure or switch is faulty Good luck
Apr 11, 2014 | Blenders
Blender has power but won"t turn on
Hello and Welcome to FixYa!
Well the mal-function can be due to numerous reasons. You need to choke out each possibility one by one.
Loose Connections ( Check for all the connections to the circuitry and motor). Bad Starter Button ( Check for the button switching using a Multi meter). Bad Motor Winding (Motor bushes or winding can be the bottle neck).
Check for the quoted possibilities and you'll soon find one good reason for the mal-function.. Feel free to ask anything regarding the trouble.
Concerned.
Feb 25, 2011 | Waring 7011S / 7011G Commercial Work Top...
We have a Jenn Air #JBL800EAAU blender that is three years old and we just love it, but it has stopped working. No electronics show up when we try to turn it on. Is there any way to trouble shoot what that might be? We did take the screws off the bottom and tried to see if anything was loose or damaged. Didn't see anything and when we put it back together, it worked for about two days. Then the same problem, it just won't light up or work. Can you help? Thanks Howard
In order to trouble shoot the problem to the root cause, you need to check each possibility one by one.
Double Check for the Power supply socket working.
Do make sure that the power cord is intact and is supplying power to the electrical equipment. For this you need to check the voltage at the internal connection of the power cord. There are cases in which the power cord is broken internally, that causes fluctuation in the supply and the device starts malfunctioning.
If the power is Ok, then you need to check for the working of the Button and the electrical motor. There is a possibility that the winding of the motor might gone faulty.
Carefully check all the above possibilities one by one.
Best of Luck,
Do RATE my solution, If FOUND helpful.
Concerned,
Waqar.
Jun 03, 2010 | Jenn-Air JBL800 Work Top Blender
1,662 people viewed this tip
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
