Tip & How-To about Televison & Video
Enter expert mode on LG TV
For the 44" LG DLP model RU44SZ63D...press and hold the menu button the remote control until a four digit password is requested on the screen. The password is 8741.
Expert mode allows the normal parameter changes as well as screen size and position, and RGB offset/gain control, for every input.
Televison & Video Logo
Best way to remove a parental lock from a lg plasma tv
LG Service Menu Instructions
Method 1
Press and Hold <OK> button on remote as well as TV panel at the same time for a few seconds.
Method 2
Press and hold the {MENU} button on the remote and the {MENU} button on the TV at the same time for at least 5-7 seconds.
Method 3
Press and hold the {MENU} button ON THE REMOTE until a 4-digit password screen is displayed.
LG Service Menu PIN/Password Codes
  • 8 7 4 1
  • 8 7 4 3
  • 7 7 7 7
  • 0 0 0 0
  • 8 8 7 8
  • 0 4 1 3
LG LCD Monitor Service Menu Instructions
  1. First turn off the lcd monitor, then press and hold the "MENU" button, then turn on the monitor. Release MENU button after the monitor is turn on.
  2. Press "MENU" button to open the OSD menu, at the bottom of menu, you can see a new selection to go into the factory service mode. Inside the factory service mode, you can see useful information like, product model, manufacturer date, F-ENGINE chipset version, lcd panel number and etc.
Mar 16, 2016 | LG Televison & Video
can the service menu for the LG 52sz8d dlp tv be accessed from the orig remote not the service remote just installed new lamp and tv was working fine for 1 week now the lamp indicator light comes on and flashes red then shuts off
One possible solution to access the service menu on LG tv's is as follows with steps 1 - 4:
1. With the TV on, press and hold the MENU button on the TV front panel.
2. While holding that button, press and hold the MENU button on your remote.
3. Hold both buttons for ~5 seconds until the service menu comes up on the TV.
4. Release the remote MENU button first, then the TV MENU button.
If you are looking to reset the lamp indicator then continue with the following steps 5 - 11:
5. Press and hold the ENTER (or OK) button on the TV front panel.
6. While holding that button, press and hold the MUTE button on the remote.
7. Hold both buttons until the Lamp Life Hours show up on your TV screen.
8. Release the MUTE button first, then the ENTER button on the TV front panel.
9. Make a note of the lamp hours if you want.
10. To reset the lamp hours, press the SELECT button (the one between the four arrow keys with two concentric circles on it) on your remote.
11. It will ask you to confirm the reset--press SELECT again to confirm.
To verify you've reset the hours, you can repeat steps 1-9 above and then just press the EXIT button on your remote.
Hope this helps. Regards, James.
Apr 22, 2010 | LG 52SX4D 52" HDTV
42LH40 - Problem with sound not being insync with picture
found this floating around online:
1) press and hold the menu button on the side of the TV then press and hold the menu button on the remote until the display says "Enter Password"
2) enter four zeros from the remote control to get past the password screen (you should now see an "IN START" menu with all kinds of information listed)
4) look at the lower left corner where there should be a numbered menu -- menu option 4 should say "System"
5) use the down arrow until the word "System" is highlighted (pressing the number '4' will not take you down the menu) and press the enter key (you should now be on the System menu near the middle of the screen)
6) press the down arrow to option 9 "Lip Sync Adjust" and then press the left arrow to adjust the value to zero (mine was set to 20 from the factory)
7) press the return key to get out of the menu and bingo, you're done!
Oct 03, 2009 | LG 42LH40 LCD TV
Z44SZ80/Z52SZ80 | DLP PROJECTION service codes
1. Press and hold the MENU button on the TV.
2. Press and hold the MENU button on the REMOTE
(Hold both until the service menu pops up)
3. Press and hold the ENTER button on the TV
4. Press and hold the MUTE button on the REMOTE
(Hold both until the LAMP LIFE HOURS appears on the screen)
5. To reset the lamp counter and turn off the orange light press select on the REMOTE.
6. Press Select again to con firm the operation.
Jul 09, 2008 | Zenith E44W46LCD 44" Rear Projection...
Lamp timer
the password according to the lg service dept is 7777
Jun 14, 2008 | LG RU-44SZ63D Television
1,492 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
