Tip & How-To about Computers & Internet
Backing Up Windows Registry
Backing up the windows registry is good practice.
There are two methods to back up your Windows registry.
1. Using the built-in Windows semi-automated tool.
Go to Start
Select All Programs
Then select Accessories
Then select System Tools
Then select System Restore
Follow the instructions to Create a Restore Point. With the restore point, you can revert your entire machine back to a point in time.
2. Using the Window Registry editor.
Go To Start
Select Run
Type in "Regedit" into the text box and hit the Enter key
To create a backup, select File
Then select Export
Name the file, I always use today's date
select all for export range,
Save somewhere you can find I use a Flash Disk
Steps to restore your registry to this backup
1. Find File on Flash Drive
2. Double click it and confirm that you want to change the registry.
Computers & Internet Logo
recycle bin does not appear on desktop. how do I fix
Try right-clicking your desktop and selecting "properties." On the window that comes up, select the "desktop" tab, then click "customize desktop." On the next window, select "recycle bin (full)" and click "restore default," then repeat with "recycle bin (empty)."
If that doesn't work, when using Tweak UI, just left-click "desktop" (NOT the plus sign next to it) and you'll be presented with a list of possible desktop options. Just make sure that Recycle Bin is checked. You can also click "repair" in Tweak UI, then select "rebuild icons" from the drop-down menu and click "repair now."
Jun 04, 2011 | Computers & Internet
How do I logon as administer
The built-in Administrator account is hidden from Welcome Screen when a user account with Administrator privileges exists and enabled. In Windows XP Home Edition, you can login as built-in Administrator in Safe Mode only. For XP Professional, press CTRL + ALT + DEL twice at the Welcome Screen and input your Administrator password in the classic logon window that appears.
To have the Administrator account displayed in the Welcome Screen, try one of these methods:
Method 1: Using TweakUI Power Toy for Windows XP Download TweakUI from here: v2.00 for Windows XP | v2.10 for XP SP1 and above
Open TweakUI and click "Logon" option in the left pane. Put a checkmark against the option "Show Administrator on Welcome Screen". Click OK to close TweakUI. Logoff and see if Welcome Screen lists Administrator login. Changes are immediate and you can use the Winkey + L to switch back to Welcome Screen to see Administrator account is listed.
Use this procedure to hide/unhide any user account from the Welcome Screen. Please remember, you can still login to a hidden account using CTRL+ALT+DEL classic logon method, but cannot Fast User Switch to a hidden user account.
Method 2 - Manual registry edit
  • Click Start, Run and type Regedit.exe
  • Navigate to the following key:
HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon \ SpecialAccounts \ UserList
  • Use the File, Export option to backup the key
  • Create a new DWORD Value named Administrator
  • Double-click Administrator, and set 1 as its data
  • Exit the Registry Editor.
For Windows XP Home Edition While you can configure Windows XP Home Edition to show Administrator account in the Welcome Screen, you cannot login as Administrator in Normal mode. Visit the following link for more information:
Error Message: Unable to Log You on Because of an Account Restriction
Please post your feedback and Vote if the problem resolved as per your satisfaction.
May 20, 2010 | Computers & Internet
how to get Vista ricovery cd's?
If you have a valid license with your laptop, and it sounds as if you do, all you need to do is contact Microsoft and activate your installation. Since the internet activation apparently has failed, here are two additional methods:
Activate Windows Vista by using the automated telephone system loadTOCNode(2, 'resolution'); To activate Windows Vista by telephone, you must use an automated telephone system. To activate Windows Vista by using the automated telephone system, follow these steps:
  1. Click Start, and then click Computer.
  2. On the toolbar, click System properties, and then click Click here to activate Windows now in the Windows activation section.
    If you are prompted for an administrator password or for a confirmation, type the password, or click Continue.
  3. Click Show me other ways to Activate.
  4. Click Use the automated phone system, and then follow the instructions.
uparrow.gifBack to the top Method 3: Contact Microsoft loadTOCNode(2, 'resolution'); If Windows detects that the hardware on your computer has changed significantly, and the previous method does not solve your problem, you may have to contact Microsoft for help. To view the Microsoft Activation Centers Worldwide Telephone Numbers list, visit the following Microsoft Web site: http://go.microsoft.com/fwlink/?LinkId=71142
It may be best to go directly to Method 3, find the phone number and call MS. Once you explain your situation they should activate without any issue.
Good luck, and please let me know how this works out for you.
~ Spoem
Apr 27, 2009 | Computers & Internet
no rights to run control panel requires new instal need media
1. to gain rights do the following.
Sep 17, 2008 | Computers & Internet
202 people viewed this tip
David Payne
David Payne
