Tip & How-To about Exercise & Fitness
How to bump start a 110cc pitbike or 125cc pitbike
At first push your bike to a hill (dosnt matter how big or small)
remember where you can put it into second gear hold the cluch in and push down the hill and let out the cluch and jump as soon as it bites then it should fire up same as a car but harder on a pit bike as you got too much throttle you will flip it and gotta do it all again haha hope this was helpfull
if it still doesnt fire up then you have a problem with your bike
IMPORTANT........................................................................
1. make sure the petrol is on and the bike isnt flodded
2. make sure not too much throttle or it could be dangerous and if you do flip it lose go straight away
Exercise & Fitness Logo
How do i push start my dirt bike ?
Put in 1st or 2nd gear hold clutch in push bike at good paces jump on it let clutch out give some gas & bam bike has been bummed started ps if not working trying pushing it faster or just roll down a hill
Aug 25, 2013 | Motorcycles
my cluch is not releacing
The clutchs start to stick together after they have been sitting for a while. Most of the time, you can hold the brake and clutch while starting, and they will break loose. If not, you'll have to remove the clutch cover and seperate the clutch discs, then put them back in.
Apr 27, 2012 | 2006 Yamaha YZF-R1
I was just given a diamondback SHERWOOD bike. I don't know how to use the gears -- what's the right shifting pattern for hills
Google "bicycle shifting technique", for example:
http://coachlevi.com/cycling/complete-beginner-guide-to-bicycle-gears-shifting/
You should NEVER run cross-chained (big-big or small-small). The drive train performs best when the chain line is as close to straight as possible.
Excess sideways stress on the chain will wear it out prematurely and decrease its normal efficiency.
To demonstrate this for yourself, put the bike in the same combination of gears you
Apr 01, 2011 | Diamondback Cycling
no pull start
I think you mean no kick start. Yes there is a way. Push starting it. With you on the bike and another person pushing. A slight downward hill helps also. Just turn on the key and the choke, put the bike in second gear. With the clutch pulled in, start pushing down the hill and when you get some speed, then pop the clutch. The engine should turn over and start.Note : Make sure you are in safe surroundings when attempting this maneuver. Happy Travels.
Apr 24, 2009 | 2005 Harley Davidson XL 1200 C Sportster...
766 people viewed this tip
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
