Tip & How-To about Panasonic DMR-E50 DVD Recorder
DMR-E50 Fixed!
My E50 stopped working yesterday. All that was working was the cooling fan. I knew it had to be related to the power supply, so I got a screwdriver.
I found that the power supply board inside had two "bulging capacitors". For those that don't know, these are capacitors that look sort of like Jiffy Pop popcorn. The top is puffing up like it's going to explode. A good capacitor should be flat on top.
I carefully removed the existing (bad) capacitors, and I replaced them with similar rated capacitors that I yanked from an old computer motherboard. You can also buy them online for about twenty-five cents a piece. After soldering them on the board, I put everything back together.
I carefully plugged the unit back in, not 100% sure that something would explode.
WOW! It came on... not only that, but it played a disc. After that, I recorded a show. My recorder is back!
I just wanted to share this in case any of you with the DMR-E50 were heading to the trash can. I should also add that any of you not experiencing power problems, but maybe having inconsistent behavior, might want to check the capacitors. I know from experience that PC's with bulging capacitors have a variety of symptoms including just shutting off out of the blue.
I hope this helps somebody out there. Just remember to unplug everything and be careful. That's my disclaimer so I don't feel guilty. :)
Panasonic DMR-E50 DVD Recorder Logo
AVE ERROR CODE 5351 WHAT IS IT?
C5351 Power Supply Cooling Fan Motor Failure The Power Supply Cooling Fan Motor Lock signal remains set to H for a set period of time while the Power Supply Cooling Fan Motor is turning. • The Power Supply Cooling Fan Motor Lock signal remains set to L for a set period of time while the Power Supply Cooling Fan Motor remains stopped.
Aug 26, 2015 | Computers & Internet
error code 5351
Motor Failure
stopped.
Jul 17, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
why does the cooling fan relay stop working on a 2003 jeep grand cherokee?
It could be the computer's power supply, you can get a cheap power supply tester to find out. Else if you have a spare power supply try replacing it.
May 11, 2014 | 4Seasons 37504 Relay - Engine Cooling Fan
ERROR CODE E50 SHOWING AFTER POWER SUPPLY INTERUPTION
It was probably your washer that tripped the electric . e50 relates to the motor check the carbon brushes they will be worn out. hopefully with new brushes you will be back in action. the programme wont start with a fault on the motor
Jul 24, 2010 | Zanussi ZWF1430W Front Load Washer
1,958 people viewed this tip
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
