Tip & How-To about Heating & Cooling
Air Conditioning Programmable Thermostats - Great for Heating and Cooling
Programmable thermostats contribute to overall system performance, maximizing energy savings while providing complete comfort control. They also allow flexibility to homeowners because they can be programmed to match their lifestyle. Programmable thermostats save energy by turning down the cooling and heating system at night or at times when your home is typically unoccupied.
Did you know that properly using a programmable thermostat in your home is one of the easiest ways you can save energy, money. Homeowners can save about $180 a year by properly setting their programmable thermostats and maintaining those settings. They can achieve significant energy and money savings that are possible through the proper use of your programmable thermostat. Programmable thermostats do two things:
(1) Compare the thermometer reading of a room's temperature to the "ideal" thermostat temperature you select.
(2) Give start-and-stop commands to the heating or cooling system in order to achieve an indoor temperature that is as close to your "ideal" thermostat setting as possible.
Your savings will largely depend on the length of your energy saving program periods and the temperatures set. For example, an energy saving period of 10 hours with the temperature set back 10° will save more than a 5 hour energy saving period with the temperature set back 5°. By maintaining the highest or lowest required temperatures for four or five hours a day instead of 24 hours, a programmable thermostat can pay for itself in energy saved within four years.
A programmable thermostat will keep you and your home comfortable while you are there to enjoy it, and will change the set point at programmed times to an energy savings level when you are not home. The precise temperature control of a programmable, energy-saving thermostat saves wear and tear on high-efficiency heating and cooling equipment by properly cycling the equipment. A programmable thermostat will keep you and your home comfortable while you are there to enjoy it, and will change the set point at programmed times to an energy savings level when you are not home.
Controlling your heating more effectively could save you up to 17% on your heating costs. In fact, during the winter you can save about 3 percent of your heating costs for every degree you lower your thermostat. Begin lowering your heating bill immediately with the pre-programmed 7-day schedule, or modify the programming to suit your lifestyle. By delivering the heating or cooling when you need it, and optimizing temperature for activity, sleep and times you are away you can maximize your comfort level and save energy.
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
http://www.fixya.com/support/r3916016-honeywell_th8320u_thermostat
http://www.fixya.com/support/r3913560-honeywell_th8110u1003
http://www.fixya.com/support/r3902153-honeywell_rth7500d_thermostat
http://www.fixya.com/support/r3898732-lux_thermostat_500
http://www.fixya.com/support/r3869033-replacing_thermostat
http://www.fixya.com/support/r3623083-thermostat_wiring_terminal_designations
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3584298-air_conditioning_programmable_thermostat
Heating & Cooling Logo
when im on the computer the monitor shuts off a box appears saying power saving enabling monitor to shut down in a few seconds and then it restarts
Windows provides the following plans to help you manage your computer's power:
  • Balanced. Offers full performance when you need it and saves power during periods of inactivity. This is the best power plan for most people.
  • Power saver. Saves power by reducing system performance and screen brightness. This plan can help laptop users get the most from a single battery charge.
  • High performance. Maximizes screen brightness and might increase the computer's performance in some circumstances. This plan uses a lot more energy and will reduce the amount of time that a laptop battery lasts between charges.
    Note
    • High performance doesn't appear on the battery meter by default. To turn on High performance, open Power Options by clicking the Start button ?id=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33, and then clicking Control Panel. In the search box, type power options, and then click Power Options. Under Select a power plan, click Show additional plans, and then click High performance.
If these plans don't suit your needs, you can create your own power plan, using one of these plans as a starting point.
Feb 13, 2011 | Gateway 510 S PC Desktop
How to install programmable thermostat
If it is a wall furnace with a built-in thermostat(sounds like the 1 to 10 dial is the thermostat) into the control then you would need to buy an updated gas contol valve that will hook up to an external thermostat and a programmable thermostat. The old gas contol valve would need to be removed and the new one installed. Then the thermostat wires would connect to the gas control valve millivolt system. A heating company can perform this service for you and I highly recommend you have it professionaly installed if you are not experienced on this process. You could leave a gas leak or other hazardous situation if not installed correctly.
Nov 18, 2009 | Vornado TouchStone Vortex Heat 500 Heater
551 people viewed this tip
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
