Tip & How-To about Heating & Cooling
Boiler Leaking Water - The Boiler Leak may not be the boiler
Went on one call today and had another query by Facebook about this so I though why not write an article about it. Both persons were very concerned as they saw water dripping from theirs boilers. A closer inspection for both showed that it had nothing to do with the boiler its self.
There are many things that can make water leak from your boiler. If you know for sure that the water is coming from a hole in the sections then you may have a serious problem. Usually though there is an easy fix for that also, more on that in another article. Both boilers today were leaking water from the relief valve.
This valve is design to relieve the excess pressure from the boiler in case of a build up of extra pressure in the boiler. The extra pressure can come from a number of different things. A few of the causes may be a bad expansion tank, a bad fill valve or pressure reducing valve, or an open bypass valve. The bypass is easy, just close it and relieve the extra pressure. The others are not as easy.
Your expansion tank is simply a tank that allows water from the system to go in and out according to the pressure in the system. This tank contains about ½ air which acts as a cushion to absorb the extra volume of water that is created as the water is heated. Hotter water takes up more space or volume, so it needs a place to go to when it is heated. If the expansion tank is totally full of water then, it will push water out of the relief valve. Changing your expansion tank will fix the problem.
If the reducing valve or fill valve is leaking by then you can also get extra pressure in the system. A normal heating system will only run 10-20 psi pressure. Most well systems or city water is way higher than that. If the pressure in your boiler gets over 30 psi then it will begin to relieve the extra pressure by dripping water.
If you have a drip from your boiler this is what you check. First the expansion tank, the reducing valve, and the bypass valve that bypasses the fill valve. This valve is usually installed to quick fill the system, or purge the water lines of air.
Often there is just a small problem that looks like a big problem. Do not get excited and methodically check through the possibilities. You will usually find that the problem is not nearly as bad as you first thought that it was.
Heating & Cooling Logo
Where can I read about unsecured personal loans to determine which kind is best for me?
http://banking.about.com/od/loans/a/Unsecured-Personal-Loans.htm
Aug 25, 2013 | Finance
when i put my username and password in facebook and hit login it it cant load the facebook server
Hello and Welcome to FixYa!
Yes, I can see tons of such queries suddenly coming up.
The FB-Servers are down this time, please be patient it will be up soon.
Concerned, Nooh.
Aug 11, 2011 | Facebook Social Network
error on facebook page
Please do explain your query in a bit detail, what exactly is the error script you are facing... Waiting for your response...
Concerned.
Mar 08, 2011 | Acer Aspire 5500 5570-2609 Laptop
nnbbhj
Unable to understand your query. Is it really what you wanna ask... Please explain the problem you are facing, in a bit details (If any). We would try our level best to provide you with the best possible solution. Waiting for your response....
Concerned.
Mar 04, 2011 | Facebook Social Network
how to realord facebook message
Please Elaborate your query a bit more. It seems you want to display a deleted message or a message that has been previously sent/received.. For this there is an option in the middle, basically message option is the middle option on the top left corner of the Facebook screen, besides facebook text. Please, do tell me if this is not the thing, you want....
Concerned.
Feb 25, 2011 | Facebook Social Network
3,409 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
