Tip & How-To about Plumbing
Installing a new Toilet - How to install a Toilet
If you can install your own toilet then you can choose what toilet best suits your needs, as there is a very big variety in style, price, and quality of toilets. Installing your own toilet is not as big a question as you might think it is. Learn how you can install a toilet yourself. You can have your new model toilet in place in just a few hours. Probably even much less time than that.
The first thing you need to do is pick out the toilet that you prefer to have. If you are older or have health problems, consider a handicap height toilet. They are a couple of inches taller than a standard toilet and make it much easier to get up from. If you have a lot of usage than a pressure assisted toilet might also be a good fit for you. The extra water pressure will help to keep the toilet from clogging. Toilets usually come without a seat, so don't forget to buy a new one or you can save the one from your previous toilet if it will fit the bowl of the new one.
The floor does not have to be spotless before installing the new toilet, but it should be fairly clean. You will next need to install the tank onto the bowl. Set the bolts with the rubber washers on them in the holes on the tank and then set the tank on the back of the toilet bowl. Tighten the bolts gently, just expanding the washers a bit.
Next, turn the toilet bowl upside down and place an new wax ring and sleeve onto the toilet horn. The toilet bowl wax gasket works best if it is at room temperature. This will ensure the proper forming of seal. Now stand directly over the toilet and lift it turning it over and setting it down over the bolts in the flange. By doing this you will place the toilet on top of the wax ring. The bolts will come up through the holes on the side of the toilet.
Install the washers over the bolts and slowly tighten the nuts until snug, while slowly pressing down until the toilet is seated flush with the floor. Make certain that the bolts are tight enough to prevent the toilet from rocking, however do not over-tighten them. Tightening the bolts too much will cause the toilet which is porcelain, to crack. Now, reconnect the water line from the floor to the tank. To give it a nice finished look a bead of silicone caulk can be run around the base of the toilet. Remember that he caulk will be visible, so choose a color that looks good with your toilet for a professional look.
Installing your own toilet can be just that easy. In an afternoon your can pick out your new toilet, remove your old one, install your new one and have it up and flushing in no time at all! Then last of all, check for leaks!! Don't be embarrassed if you find a leak, retighten and check again. Even a pro will have a leak sometimes. Leaks happen! Good Luck!
Plumbing Logo
How to get cheap services for buying Instagram likes?
If you want to buy Instagram services at a cheaper price, you can visit the best online platform for this purpose which is buy Instagram followers.
Here, you can get varieties of options to choose the best package for you according to your need and budget. They use safe and secure way to supply best services to their customers at reasonable prices.
Sep 12, 2017 | Computers & Internet
Cheapest online shopping
I find e-bay the cheapest with the biggest variety of products new and used
Feb 19, 2016 | Cars & Trucks
when I flush the toilet does flush fine but it makes a gasping sound as it tries to refill the tank. Eventually (after 5 minutes) the tank fills and the gasping stops.
new quality flush valves are inexpensive. suggest you buy a new one at a big box store (Lowe's e.g.) . easy to install, just follow the directions.....a Fluid Master or Gorkie should work fine...$25 or less, probably less.....
Apr 20, 2010 | Toto CST743S-04 Drake Suite Two Piece...
Can old style dual cistern be converted to new style 6/3
We have not solved the problem but after speaking to 3 Major Plumbing Supply Places
they have told us we have no alternative but to replaced both the whole toilet suite's
as older style pans don't match up with never models
Jan 04, 2009 | Home
982 people viewed this tip
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
