Tip & How-To about Heating & Cooling
Changing Oil Burner Motor - Beckett Oil Burner Repair
Your oil burner motor has stopped spinning, so you have a problem. Do you tackle the job of changing it yourself or call someone to do it. How hard of a job is it? Can you do it yourself? All these questions flood your mind. Rest easy, the job really is not that difficult and you probably can do it yourself.
Changing the motor on an oil burner is actually a very simple task. There are a few things that you will need to know that will make things go smoother for you. Always remember to kill the power before working on the burner unit.
The motor on most oil burners is the round black thing on the right hand side as you look at the burner. On the flange of the motor you will find two screws that hold the motor on. Remove these two screws and pull the motor, with the fan on the shaft,out from the main body of the burner. Sometimes the coupling to the oil pump will come along and sometimes not. It does not matter either way, you will want to check it for cracks and wear anyway.
Unhook the wires to the motor in the junction box that the protectorelay is fastened too. Two screws will loosen that enough to slide it away to get to the wires. Remember where you unhooked the wires from so you can get them back in the right place. Loosen the set screw on the fan and remove it. Take note of the gap between the side of the fan and the motor flange so that you can reinstall the fan on the new motor at the same distance.
Now install the fan on the new motor. Reinstall the old coupling, if it is in good shape or install a new one. Be careful to get the coupling on the shaft of the oil pump correctly. With many types of couplings it is easier to line up the splines of the coupling rather than the flat spot on the shaft. Tighten down the screws of the motor, while spinning the fan inside the burner housing to make sure that it is not binding up. If it begins to turn hard, then find out why and fix the problem. Burner motors are fractional horsepower and will not start if they have any resistance to turning.
Hookup the motor wires to the right connections, and replace the protectorelay on the junction box. You should now be able to restore the power to the oil burner and fire it up.
There now that was not hard at all!
Heating & Cooling Logo
how to replace oil pump
Your not doing that yourself
You better study the engine design
Either motor would take a professional a complete
day just to remove the front covers on the motor
That would be a $1,000 job for someone who has done
it a few times
Apr 01, 2014 | 2002 Lincoln Blackwood
2004 Fatboy Oil Tank Change Out
I have an '04 Fatboy and work in a dealership. Swapping the oil tank is not fun! There is very little clearance for tools and your hands! If you decide to try it yourself, get a service manual. It will make the job a little easier, with the steps you need to take to remove the tank. Or, get a service manual and read how to do it and decide if you want to tackle this job yourself.
Mar 09, 2014 | 2004 Harley Davidson FLSTF - FLSTFI Fat...
Washing machine jerks hard when stopping from the spin cycle.
The braking mechanism inside the transmission is malfunctioning... Probably a break lining has come off. Sorry to say, it's not a job for the average do it yourselfer.
Nov 20, 2009 | Coffee Makers & Espresso Machines
24622300kenmore washer
coupler broke between trans and motor,let me know if you want to tackle it,very hard job-mike
Nov 02, 2008 | Kenmore 22422 Top Load Washer
Washer make a loud squeak when the spinning stops
its the brake, just as long as it stops, dont worry about it, made a web page that has pics on how to replace the spin bearing on the maytag atlantis washer, after searching the net on how to, finding the manual, not explanatory, i decided to make this a simple 1 page web site, with lots of pictures, i hope this can help someone else in doing this job. since it would cost too much money for a repairman to do the job, better to buy a new one instead, i tackled the job. since it basically takes apart the whole machine, it might help others even if they dont have the spin bearing problem but other parts to replace,
http://www.geocities.com/maytagrepairwasher/
Apr 06, 2008 | Maytag Atlantis MAV6451 Top Load Washer
4,531 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
