Tip & How-To about Heating & Cooling
Oil burner Repair - The Frustrations of Working With Oil Fired Appliances
If you have ever tried to work on your oil burner to get it working, you know how difficult and frustrating that can be. I can totally feel for you and your feeling that you just want to take the thing out, find the biggest hammer you have and use it on the burner.
Servicing an oil burner can be one of the most humbling experiences of life. You have had success with many for quite a long time and then you get smacked down to size by this piece of equipment that just will not respond to anything that you try to do to fix it.
You have changed the nozzle and that worked for a bit. Then poof you get nothing. You checked the transformer and it throws sparks like the fourth of July. The relay seems to function great the coupling has been checked and is in great shape. The motor starts and stops like it should every time you are there. Maybe you even have a combustion analyzer and it is showing that the flame is burner great. So what do you do know?
You could pull up a chair and get a book and monitor the thing yourself. Or you could hire someone to hookup a monitor to the burner that will record what did not work properly when it fails to light. The problem with oil burners is that sometimes a part will just fail intermittently. This can drive even the best technician nuts sometimes. Anyone hates to just be a parts changer, but it is very hard to find that source of the problem in some situations.
Just remember that if you are in the situation of not being able to figure out the exact cause of the problem with your oil burner, you are not alone! I have fixed hundreds in minutes and a few in days! I have left many a burner whistling a happy tune, only to be called a few hours later that it was on the blink again. Grrrrr!
Heating & Cooling Logo
How to be totally free from self and the world
You mean shuffle off this mortal coil. That's silly.
Oct 21, 2017 | The Computers & Internet
anybody out there that knows about oil burners for a home heating boiler system???
Here is a tip that I wrote about working on oil burners...
Oil burner Repair - The Frustrations of Working With Oil Fired AppliancesYou can also check out other tips that I have about oil burners under my profile....heatman101
Nov 09, 2010 | Heating & Cooling
Coleman 424-700G Burner/Pressure Issue
I had a similar problem today, After taking the ump assembly to pieces i disovered that the pump"stem" needed turning slighty anti clckwise to allo tepresure to build up inthe tank. I felt very stupid buta big learning curve for me.
Sep 28, 2008 | Coleman 2 Burner Dual Fuel 424-700G Grill
GE Range JBP69 samller burner of the dual burner doesn't work...
These burners are not that difficult to get to, but you will have to get access to that burner or element to do testing. Screws hold the top down located just under the top front edge. Open oven door to see screws. Remove screws to lift up top. It will pivot on the back edge. You will see the elements. If you do not feel safe doing this get professional help.
Aug 01, 2008 | GE JBP65 Electric Kitchen Range
622 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
