Tip & How-To about Heating & Cooling
How to Clean Oil Heaters - Shop Vac Preparation
So you think you want to clean that or oil fired furnace or oil boiler yourself. You have watched the service guy do it and really didn’t think that it looked all that hard. You stick the hose of your shop vac into the chamber and all the soot is broadcast all over the place! Yikes, what did he have that you don’t in there?
When cleaning an oil fired appliance you need to remember that the dust created by the unit is very fine and will just go right through the filters that are standard to most shop vac’s. You will have to go to the store and find some special equipment to catch all that fine black dirt. It is very easy to find if you know what to look for.
Most vac’s have a foam filter over a cage that holds the ball on wet/dry vac’s or the cage that holds the foam filter on just dry vac’s. When you go shopping for your new filters, look for the paper filter and ring that hold the filter paper over the cage. This filter is actually your second stage of defense. To really help out you need to get your first stage.
The first stage is a paper filter bag that installs over the intake to you tank. These bags come in different sizes depending on the size of your vac. You take the bag and carefully install it in the tank making sure that the mouth of the bag is seated securely onto the intake of the tank. This bag will catch the majority of the dust and make it very easy to contain and throw out also.
Now you are ready to clean your oil furnace or oil boiler like a pro. As long as you keep everything dry you will be fine. Dampness or water will make a hole in the bag and filter which will ruin any chance of filtering your air intake properly. Also remember that you are filtering through a fairly fine media and it will plug up rather quickly. You may need to change the bag and filter a couple of times to complete a job.
One final thing for you guys. If you are planning to use the shop vac that your wife uses for her everyday cleanups, you may want to rethink this. After you get done with it and have black soot all over the nozzle and such you will be sleeping in the doghouse if your wife goes to use it and ends up with black on something good of her’s. You have now been warned. Don’t blame me for anything that happens to you as a result of not heeding this warning.
Heating & Cooling Logo
what would cause my weil mclain oil fired furnace to lock out? any help would be greatly appreciated thank yo. . Charlie
Could be the photocell (CAD cell) on a residential boiler, or a fuel problem ie dirty fuel filter, oil lines losing prime.
Mar 15, 2015 | Heating & Cooling
I ran out of oil on Wed. On Fri., they brought me oil, but I cannot get my furnace to run. I think maybe it pulled some trash into the line. What can I do?
You need to replace the inline filter and the spray nozzle. If you've never done it or don't know how have a trained professional come do it and watch him foe next time. Everytime you fill the tank with oil it will kick up some debris. So you need to at least replace the filter after filling up and it's not a bad idea to do the nozzle at the same time. Good luck!
Mar 02, 2015 | Heating & Cooling
I need to turn the temperature down on my Hydrotherm oil-fired burner. How do I do that?
On the front of the unit on the upper right is a grey box. Remove cover. Inside there should be a notched steel dial to adjust the water temperature.
Hope this helps.
Bob
Mar 04, 2014 | Hydrotherm Boiler, Oil Fired - PB-105/120W
257 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
