Tip & How-To about Heating & Cooling
How to Keep House Cool Without Using Air Conditioning
The expense of running the air conditioner is just too much. You open the house doors and windows up to try to cool the house down. But the house just seems to get hotter. Maybe you are going about it all wrong.
Here is a way for many people to have their houses cooler without running the air conditioner at all. Now I live in an area of the United States that has many cool nights even in the summer time. And I have found that this works very well for me. This will not work for everyone in every climate all the time but for a great many people at certain times of the year and under the right conditions they can save a ton of money with a minimal amount of effort and fore thought.
The trick to this is to cool your house off at night and then trap the cool air in the house during the daytime. When the sun goes down and it starts to cool off outside, open up all the windows and the doors too if that is practical where you live. Let them open all night long, even if the temperatures get rather cool over night. The idea is to get the house to cool down as much as possible.
Hopefully by morning your house is very nice and cool. Now before the sun has time to warm the air temperatures close your house up as tight as if it were wintertime. Try to limit the traffic in and out of the doors if possible. The idea now is to conserve the trapped cool air inside of the house. By doing this you will have a nice cool house all day long until evening when you do it all over again.
The best thing about this process is that is does not cost you anything. A bit of time spent opening and shutting doors and windows could save you a bundle on your electric bill. The process seems like it would not work that well but once you try it and see the results you will love the savings!
Heating & Cooling Logo
why does the air conditioner leak water from behind the unit. My air conditioner is placed in a wall and the back end of the conditioning unit sticks out inside the garage. I have ventilation by keeping the doors open. what should I do to stop the air from leaking? should I have the vent open or closed ?
It is normal for an air conditioner to leak water out the back. This water is actually the humidity being taken out of your house. Being vented out in to the garage is always an issue with condensate water. I have seen some people take a funnel and run a hose outside the garage somewhere. Keep the vent closed. It will be harder to cool the house with the vent open because it lets outside air in to the house.
Jul 04, 2011 | Friedrich Heating & Cooling
Air condition unit of sufficient size??
You currently own a 2.5 ton AC Unit
500 square feet equals a ton of cooling/ you need a 3.5 ton unit.
If your home is well insulated, good windows and doors and pretty good
shade that covers your house, then I can see a 3ton unit cooling your
house.
Thats another 6,000 btus you do not have and that is a best case for a
energy effcient home.
Jul 07, 2010 | Carrier 38CKC030 Air Conditioner
Airflow throughout House
The system you have installed what is the kw cooling capacity? do you only have one evaporator installed?
Jun 09, 2009 | Fujitsu 18RC Air Conditioner
buttons
F1, F2, and F3 are the strength of the fan blowing the air conditioner. F1 circulates the least amount of air, F3 the most. I generally find that if the air conditioner isn't getting the job done on F1, F2 will do it. I typically only use F3 if I just want to circulate air fast in my place for awhile. As far as what is "better" with closed vent or open, that depends on what you want to do. If you are using air conditioning on a hot day, then vent closed is better because it will cool only air circulating in your place. Vent open will allow fresh air in from outside, and if it's a really hot day, the air conditioner might have a harder time cooling off the fresh air than the circulating air inside your place (as it's continually being cooled repeatedly by your air conditioner).
Jun 10, 2008 | Goldstar M1003R Air Conditioner
2,856 people viewed this tip
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
