Tip & How-To about Computers & Internet
How To Reinstall A Computer's Operating System
First
Put the installation disk that came with your computer in the disk tray
Second
Turn you computer off
Third
Turn you computer back on
Fourth
Press F12 of F10 (this enters the boot menu)
Fith
Select the cd drive that you have placed the install disk
Sixth
at the bottom of the screen it will tell you what to press to go further with the install process
Seventh
It will ask what to do with the partision,Just install on to the partision
Eight
after the partision it will ask what type of format that you want(pick the quick FAT format
Nine
now it will take over but you will have to put in some input to help customize the computers software so that it is better for you
Computers & Internet Logo
bike will not turn over, security icon flashes alone with the turn signals. Battery test OK.
Have you used the new PIN to manually disable the security system?
Do not turn handlebars, straddle seat or lift motorcycle off the jiffy stand. During a PIN disarm, if the security system detects motorcycle motion the system will activate.
Turn ignition to IGN.
If armed, the odometer window display will read: ENTER PIN and the security lamp will be flashing at a fast rate. The headlight will not be on.
Press and release the left turn signal switch.
In the odometer window, a flashing 1 will appear.
Increment the digit by tapping the left turn signal until the odometer window displays the first digit of the PIN.
The first digit in the odometer will be the first digit in the PIN.
Press right turn switch 1 time.
The first digit is stored and the next digit will flash.
Increment the second digit using the left turn switch until the digit reaches the second digit of the PIN.
The second digit in the odometer will be the second digit in the PIN.
The second digit is stored and the next dash will flash.
Increment the third digit using the left turn switch until it reaches the third digit of the PIN.
The third digit in the odometer will be the third digit in the PIN.
The third digit is stored and the next dash will flash.
Increment the fourth digit using the left turn switch until it reaches the fourth digit of the PIN.
The fourth digit in the odometer will be the fourth digit in the PIN.
The fourth digit is stored and the next dash will flash.
Increment the fifth digit using the left turn switch until it reaches the fifth digit of the PIN.
The fifth digit in the odometer will be the fifth digit in the PIN.
The fifth digit is stored. The security system indicator lamp stops blinking.
Smart Security System is disarmed.
If a mistake is made while entering PIN, turn the ignition Switch to OFF before entering the last digit and then start the procedure from the beginning.
If the procedure fails to disarm the security system, wait two minutes before attempting another PIN disarm.
The security system will remain disarmed until the ignition is turned to OFF.
Apr 04, 2014 | 2005 Harley Davidson FLHTCUI Electra Glide...
Just bought a Philips Mp3 player, know nothing about how to use or load, directions only have pictures, where do I get the manual off the internet to read. Remember I don't know a thing about how to use it, or load songs on it.
First, the device would have been provided with a cable from which connection would be made to the computer. Second, the device would have likely been acquired together with an installation disk. The disk should be installed on the computer because contained the program that would hold media for transferability perposes. Third, once software has been installed every available media would be compiled onto an area called the transfer library or player list for manipulation. Fourth, at which point connecting the device to the computer should be ready for transfer. The device is simply recognised by the computer program that was installed on the computer making way for feartures like transfter, save, edit, and the like.
Jan 19, 2011 | Cameras
Will not read disks. Cycled power usally worked not this time.
First Turn your X-box on
Second Take out your game or CD
Third Open tray
Fourth Close tray
Fifth Repeat Third and Fourth a couple times and let it load then open
Sixth Stop when you hear the xbox make a spinning noise like when it is reading a game
Seventh Open tray
Eighth Pit a game in
Ninth Close tray
Tenth Play you game!
Dec 30, 2010 | Microsoft Xbox 360 Console
need the diagram to a 95 chevy suburban 5.7 350 motor on how to put the spark plug wires fron the block to the distributor in order
there should be numbers on the top of the distributor and chevy numbers there v8s like this number one is drivers front plug 2 is pass. front plug 3 is drivers side second plug back 4 is pass side second plug back 5 is drivers third back 6 is pass third back 7 is drivers fourth back 8 is pass. fourth back firing order is 18436572 thats the order the distributer hits the wires incase there are no numbers you can put the engine at top dead center just pull the number one plug and turn the engine by hand at the crank i thing its a 7/8ths bolt in the center always turn right (left takes out the bolt) put your finger on the plug hole when you fill air being pushed out then grab a long flat head screwdriver stick it in the hole and slowly turn the engine till the screwdriver is at its highest point then pull the dist. cap off and see were the rotor is pointing that is number one the next one is 8 then and so on i dont remember what way the dist. turns so you can see by turning the engine a little more the dist. will turn with it. hope this helps
Mar 08, 2010 | Chevrolet Suburban 1500 Cars & Trucks
156 people viewed this tip
David Payne
David Payne
