Tip & How-To about Health & Beauty
Shoprider speedup tip
This tip applies to the following model 4 Wheel Sovereign 888.
Remove the control panel or tiller panel , the same thing,
Look below the black box and you will see a speed pot, turn this is the right and you should notice the scooter now goes slightly faster.
Experiment to get the best results.
Regards
gewiz.
Health & Beauty Logo
How to install a blower moter and fan
Well, here's the instructions from the service manual. The labor guide says this can be done in 1.6 hours...I don't see how, unless the instructions are wrong about having to remove the instrument panel. My thoughts are that if you are only doing the blower motor, the blower assembly will come out without pulling the dash. You probably only have to do a partial disassembly and remove the glove box and the glove box lower support.
BLOWER ASSEMBLY
Removal and Installation
1. Disconnect battery ground cable. Remove Instrument panel. (See Instrument Panel Removal) Disconnect resistor connector. remove blower assembly duct. Disconnect motor connector. Remove blower assembly
2. Remove blower assembly screws and blower motor assembly. Remove clip and fan from assembly. Separate motor case and remove blower motor. To install, reverse removal procedure.
INSTRUMENT PANEL
Removal
1. Disable air bag system. See AIRBAG RESTRAINT SYSTEM article in ACCESSORIES/SAFETY EQUIPMENT SECTION. Disconnect negative battery cable. Scribe mating marks on steering wheel and shaft for installation reference. Using Steering Wheel Remover (J-29752) remove steering wheel. Remove steering cowl.
2. Remove instrument panel grilles and plug, or driving pattern indicator panel (A/T Models). Disconnect electrical connections. Remove instrument panel hood, instrument cluster ezel and instrument cluster. Remove hood release handle. Remove knee protector.
3. Remove dash fuse/relay block and side trim. Remove engine control module box. Remove radio console and glove box lower reinforcement. Remove speaker covers and glove box. Remove heater control panel knobs and cover. Disconnect heater control cables, and remove heater control panel. Remove illumination control knob. Remove instrument panel.
Installation
1. Install instrument panel. Install and adjust heater control cables. To complete installation, reverse removal procedure. Ensure mating marks on steering wheel and shaft align. Apply grease to contact ring and tighten steering wheel nut to 26 ft.lbs. (35 N.m).
Feb 28, 2011 | 1995 Isuzu Rodeo
Need to remove heater A/C dash control , what is proper procedure?
Look at fig. 4 for the heater a/c dash control: HEATER CORE Altima REMOVAL AND INSTALLATION
  1. Position the steering wheel in the straight-ahead position.
  2. Turn the ignition switch OFF.
  3. Disconnect the negative (() battery cable; then, the positive (+) battery cable. NOTE: Wait for a least 3 minutes after disconnecting the battery cables for the charge in the air bag circuit to dissipate before working on the air bag module(s).
  4. Remove the driver's side SRS and steering wheel by removing or disconnecting the following:
    • Lower lid from the steering wheel and disconnect the driver's air bag module connector
    • Left and right side lids from the steering wheel
    • Special bolts from both side of the steering wheel using a tamper resistant Torx wrench (T50)
    • Air bag module and store it face up
    • Horn's electrical connector and remove the steering wheel nut
    • Steering wheel from the steering column using a suitable puller
  5. Remove the passenger's side SRS by removing or disconnecting the following:
    • Glove box door and the glove box
    • Front passenger's air bag module connector
    • 2 special bolts using a tamper resistant Torx wrench (T50)
    • 4 passenger's air bag-to-instrument panel nuts
    • Front passenger's air bag module and store it face up.
  6. Drain the cooling system into a clean container for reuse.
  7. Discharge and recover the air conditioning system refrigerant.
  8. Working in the engine compartment, disconnect the heater hoses from the heater core tubes.
  9. Remove the instrument panel by removing or disconnecting the following:
    • Kick plate and dash side finisher on the driver's side
    • 2 lower panel-to-instrument panel screws and the lower panel on the driver's side
    • 2 lower reinforcement panel-to-instrument panel screws and the lower reinforcement panel
    • 6 steering column cover screws, the covers, the spiral cable and combination switch
    • 2 cluster lid "A" screws and the cluster lid "A"
    • 3 combination meter screws, disconnect the electrical harness connector and remove the combination meter
    • Switch panel
    • Instrument panel lower covers
    • Snap out the transmission shifter finisher (boot)
    • 4 cluster lid "C" screws and the cluster lid "C"
    • 4 audio and deck pocket-to-instrument panel screws and the audio and deck pocket
    • 5 center console screws and the center console
    • 2 center instrument panel screws and the center panel
    • front defroster grilles
    • Front pillar garnish
    • Instrument panel 3 nuts/4 screws and the instrument panel
    • 8 instrument stay assembly nuts and the stay
    • Steering member assembly 5 nuts/1 bolt and the steering member
  10. Remove the air conditioning housing assembly by removing or disconnecting the following:
    • Refrigerant lines from the air conditioning housing assembly
    • Thermo control amp
    • Air conditioning housing assembly
  11. Remove or disconnect the following:
    • Heater unit
    • Heater core from the heater unit Fig. 1: Exploded view of the steering wheel and air bag module 93112gd9.gif
      Fig. 2: Exploded view of the passenger's side air bag module 93112gd0.gif
      Fig. 3: Exploded view of the instrument panel assembly 93112ge1.gif
      Fig. 4: Exploded view of the heater housing assembly and related components 93112ge2.gif
      Fig. 5: View of the heater core and heater housing 93112ge3.gif
    To install:
  12. Install or connect the following:
    • Heater core to the heater unit
    • Heater unit
  13. Install the air conditioning housing assembly by installing or connecting the following:
    • Refrigerant lines to the air conditioning housing assembly
  14. Install the instrument panel by installing or connecting the following:
    • Steering member assembly and the steering member 5 nuts/1 bolt
    • Instrument stay assembly and the 8 stay nuts
    • Instrument panel and the instrument panel 3 nuts/4 screws
    • Front defroster grilles
    • Center instrument panel and the 2 center panel screws
    • Center console and the 5 center console screws
    • Audio and deck pocket and the 4 audio and deck pocket-to-instrument panel screws
    • Cluster lid "C" and the 4 cluster lid "C" screws
    • Snap in the transmission shifter finisher (boot)
    • Switch panel
    • Combination meter, connect the electrical harness connector and install the 3 combination meter screws
    • Cluster lid "A" and the 2 cluster lid "A" screw
    • Combination switch, the spiral cable, the covers and the 6 steering column cover screws
    • Lower reinforcement panel and the 2 lower reinforcement panel-to-instrument panel screws
    • Lower panel and the 2 lower panel-to-instrument panel screws, on the driver's side
    • Kick plate and dash side finisher, on the driver's side
  15. Working in the engine compartment, connect the heater hoses to the heater core tubes.
  16. Install the passenger's side SRS by installing or connecting the following:
    • 2 new special bolts and torque using a tamper resistant Torx wrench (T50) to 11-18 ft. lbs. (15-25 Nm)
  17. Install the driver's side SRS and steering wheel by installing or connecting the following:
    • Steering wheel to the steering column
    • Steering wheel nut and torque the nut to 22-29 ft. lbs.
    • Air bag module
    • New special bolts to both sides of the steering wheel and torque the bolts using a tamper resistant Torx wrench (T50) to 11-18 ft. lbs. (15-25 Nm).
    • Both the left and right side lids to the steering wheel
    • Lower lid to the steering wheel and connect the driver's air bag module connector
  18. Refill the cooling system.
  19. Connect the positive (+) battery cable; then, the negative (() battery cable.
  20. Evacuate, charge and leak test the air conditioning system refrigerant.
  21. Operate the engine to normal operating temperatures; then, check the climate control operation and check for leaks.
Nov 19, 2010 | 2002 Nissan Sentra
how do I adust the emergency brake
There is an adjuster under the console. See instructions below from autozone.com:
    1. On vehicle with low series floor console:
    1. If equipped, remove the manual transmission shift knob by turning counterclockwise.
    2. Remove the floor console front finish panel.
    3. Apply the parking brake, then remove the floor console rear finish panel.
    1. On vehicle with high series floor console:
    1. Apply the parking brake.
    2. Remove the floor console finish panel.
    1. Remove the adjustment nut clip.
    2. Turn the parking brake control adjustment nut so that the parking brake control stroke is three to five notches when pulled.
      0996b43f80204da9.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Turn the parking brake control adjustment nut so that the parking brake control stroke is three to five notches when pulled
    3. Confirm the parking brake is applied.
    4. Install the adjustment nut clip.
    1. On vehicles with high series floor console:
      1. Install the floor console rear finish panel.
    1. On vehicles with low series floor console:
    2. Install the floor console front finish panel. If equipped, install the manual transmission shifter knob by turning clockwise.
  • Sep 12, 2010 | 2004 Ford Escape
    i am remove heater core from nissan xterra 2000 do i need to remove the evaporator
    2000-02 Frontier And Xterra
    1. Disconnect both the negative (1st) and positive (2nd) battery cables.
    2. Remove the steering wheel by performing the following procedure:
      1. Turn the ignition switch to the OFF position.
    CAUTION Wait 3 minutes after disconnecting the battery cables and turning the ignition switch to the OFF position before servicing the air bag system.
    1. Remove the lower lid and disconnect the driver-s air bag module connector.
    2. Remove both side lids.
    3. Using the Tamper Resistant Torx® Wrench size T50, remove the special bolts from both sides of the steering wheel and discard them.
    4. Remove the SRS module from the steering wheel.
    CAUTION Always store the SRS module face up.
    2. Disconnect the horn connector and remove the steering wheel nut.
    3. Using a steering wheel puller, press the steering wheel from the steering column.
    1. Remove the passenger-s side air bag by disconnecting or removing the following items:
    1. Open the glove box door.
    2. Working inside the glove box, open the lower instrument panel lid.
    3. Remove the passenger-s air bag module connector clip from the lid.
    4. Disconnect the passenger-s SRS module connector.
    5. Remove the glove box and the lower passenger-s side instrument panel.
    6. Using the Tamper Resistant Torx® Wrench size T50, remove the SRS module-to-instrument panel special bolts and discard them.
    7. Remove the 4 SRS module-to-instrument panel mounting nuts.
    8. Release the SRS module-to-instrument panel clips and remove the SRS module.
    1. Drain the cooling system into a clean container for reuse.
    2. Working inside the engine compartment, disconnect the 2 heater hoses from the heater core.
    3. Discharge and recover the air conditioning system refrigerant.
    4. Disconnect both refrigerant lines from the evaporator core. Plug the lines to prevent moisture from entering the system.
    5. Remove the glove box and the mating trim.
    6. Disconnect the thermal amp connector.
    7. emove the air conditioning housing assembly from the vehicle.
    8. Remove the instrument panel assembly by performing the following procedure:
      1. Remove the 4 steering column cover screws; then, separate and remove the steering column covers.
      2. Remove the 2 driver-s side lower instrument panel screws and the lower instrument panel.
      3. Remove the 4 cluster cover screws and the cluster cover.
      4. Remove the 6 combination meter screws; then, disconnect the combination meter electrical connector and remove the meter.
      5. Remove the 2 glove box screws and the glove box.
      6. Remove the 2 instrument stay cover screws; then, disconnect the electrical harness connectors and remove the stay cover.
      7. Remove the 2 cluster lid -C- screws; then, disconnect the electrical harness connectors and remove the cluster lid -C-.
      8. Remove the 4 audio and deck pocket screws; then, disconnect the electrical harness connectors and remove the audio and deck pocket.
      9. Disconnect the ASCD main switch connector.
      10. Remove the 2 meter cover screws; then, disconnect the electrical harness connectors and remove the meter cover.
      11. Remove the 4 air conditioning-heater control screws; then, disconnect the control cables and remove the air conditioning-heater control.
      12. Remove the front pillar garnish.
      13. Remove the 3 instrument panel assembly nuts and 2 bolts; then, remove the instrument panel.
    9. Remove the heater housing assembly.
    10. Remove the heater core from the heater housing assembly.
    continue...
    Jul 16, 2010 | 2000 Nissan Xterra
    how i revome the stereo on my chevy malibu 2006
    Disconnect the negative battery terminal
    to prevent an accidental short
    circuit.
    Unclip and remove wood grain/painted
    trim pieces from both sides of
    steering wheel. (Figure A)
    Unclip and remove side panel from
    driver’s side of dash with door open
    and remove (2) 7 MM screws.
    (Figure B)
    Remove (2) 7 MM screws from bottom
    edge of panel below steering
    wheel, unclip panel and let hang. It
    is not necessary to completely
    remove panel. (Figure C)
    grain/painted trim piece from above
    glove box.
    passenger side of dash with door
    open and remove (2) 7 MM screws
    from behind panel
    of glove box then open box and
    squeeze sides together to open further
    and remove the remaining (4)
    7MM screws. Unclip the black vent
    cover under the glove box then unclip
    and remove entire glove box assembly.
    (Figure F)
    7
    Unclip and remove trim panel surrounding
    radio and climate controls.
    (Figure G)
    8
    Remove (4) 7 MM screws securing
    the radio and (2) 7 MM screws securing
    the climate control. Unplug and
    remove the radio. (Figure H
    Feb 08, 2010 | Sony Car Audio & Video
    1,429 people viewed this tip
    Top Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
