Tip & How-To about Garden
Chainsaw tune-up
When you buy a chainsaw the carburetor is set to run at sealevel basically. The fun thing about chainsaws is you can go to the top of the mountain and cut firewood. There is a lot of difference in elevation so the carburetor settings you use at your house might not run good at the top of the mountain so it is benificial to know how to quick tune your chainsaw.
You need to set the mixtures for the carburetor. There is usually a rubber grommet on the side of the housing near the carburetor. You will find a Low and High adjustment screw. The default setting for the H and L carburetor jet is usually to turn them in all the way till they stop and back them out a turn and a half. You should start the chainsaw and warm it up untill it will run without choking. Make sure that the air filter is cleaned. Start by turning the low adjustment screw out. You will notice that the rpms should start increasing. keep turning it out until the rpms start to drop then turn it back in a quarter of a turn from where it idled at the fastest rpm. At this point you may need to adjust the idle adjustment till the saw idles at a good speed but not fast enough that the chain turns. You may need to readjust the idle speed so the chain doesn't turn during idle. To set the high adjustment screw will require that you run the saw at max RPM. It may be a good idea to get someone to hold the saw so the bar doesn't hit anything while you're doing this. Hold the throttle trigger all the way down and then turn the high adjustment screw in and out until you find maximum rpm. Turn the screw back in a quarter turn. Your saw is now tuned for the elevation you're currently at.
Garden Logo
cant stay running
What to do if your chainsaw won't stay running?
arborist101.com/what-to-do-if-your-chainsaw-wont-stay-running/
Idle ports may be plugged or blocked - This is the small ports in the carburetor where the fuel passes through when in idle. ... Vent in the Fuel Cap is plugged - If the vents in the fuel caps are clogged the fuel becomes vacuum locked. ... Starting with the High Speed screw, turn it ...
Craftsman 16" Chainsaw Fix - Won't Run - Fixed! - YouTube
? 1:32
https://www.youtube.com/watch?v=aIUVQziXBPY
Jul 7, 2011 - Uploaded by BriggsRepair
Is this Craftsman 16" chainsaw broken? Hardly. Watch this carburetor fix and how it runs brand new!
Chainsaw won't stay running - DoItYourself.com Community Forums
www.doityourself.com/.../360759-chainsaw-wont-stay-running.html
Sep 20, 2008 - Chainsaw won't stay running. Craftsman 16" chainsaw, fuel/oil ratio 40:1. Saw is 10 years old, used once or twice a season. Last used in spring ... chainsaw wont stay running
Aug 1, 2015
Craftsman chainsaw won't stay running
Oct 30, 2010
Chain saw won't stay running
Oct 2, 2006
Poulan Chainsaw - starts but won't run
Apr 28, 2006
More results from www.doityourself.com
Why won't my chainsaw stay running? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 31, 2016 | Garden
How do I reset carb. screws to factory settings
Adjustment and Tuning of a Chainsaw Carburetor ' Chainsawr
store.chainsawr.com/.../tuning.../1126042-adjustment-and-tuning-of-a-c...
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws and other two-cycle engines. ... These saws have what is called a "fixed jet" which is set from the factory. ... (7) Go back to step (5) and reset the idle speed. ... NOTE: If you do not have a tachometer, set the RPM level so that the saw "four ...
How to Adjust the Air and Fuel on a Stihl Chainsaw ' Home ...
homeguides.sfgate.com > ... > Adjustable Mortgage Rates
Return a type A carburetor to its factory setting by turning the "H" screwcounterclockwise until it ... Where Do I Find the Carburetor on My Stihl 017 Chainsaw?
how to adjust carbs on 2 stroke weedeaters and chainsaws ...
Dec 25, 2015 | Garden
Could some help me with factory carb settings on this saw
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws ... These saws have what is called a "fixed jet" which is set from the factory.
Stihl Chainsaw Carburetor Adjustment - Tune-up Settings
tekindoor.com > MISC
Stihl chainsaw's have three carburetor adjustment screws (LA) Idle Speed screw - This ... When the engine is tested at the factory the carburetor is set to obtain a ...
The fuel/air mixture in any gasoline-powered engine is regulated by the carburetor, and the carburetor in a Stihl chainsaw is factory-adjusted to provide the best performance.... You'll find three adjustment screws for the carburetor, usually located under the air filter cover.
Factory carb setting on Craftsman 2.0 or Poulan Micro ' Firewood
Dec 04, 2015 | Garden
having problems running my chainsaw?
If airfilter is clean and have good gas in tank. And you hawe checked ideal settings for carburetor. Possible problem with the carburetor. A faulty carburetor diaphragm or even a broken crankshaft seal.
Dec 19, 2012 | Stihl MS362W Chainsaw
poulin p3314 gas runs out carb
Set the H and L jet screws CW to stops (lightly), then CCW 1-3/4 turns each. This is a basic setting and both need to be turned CW somewhat when the engine runs. Recheck the lower chamber in the carburetor for correct installation of the needle, seat, spring, fulcrum, and diaphragm. Go to: www.drystacked.com for a detailed look at Walbro brand carburetors. Even if you do not have a Walbro carburetor, the principles are much the same. Make sure the fuel tank vent is open.
Mar 27, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
662 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
