Tip & How-To about Heating & Cooling
What to do if you run out of Fuel Oil - Beckett Oil Burner Problems
Running your furnace out of heating oil is not that uncommon. There are many different things that can go wrong to cause you to run out. If this happens to you do not panic, you can get your oil burner running rather quickly. You just need to know what to do.
You forgot to order more heating oil for your heater and now you have run it out of oil. The first thing you need to do is find a container that will hold at least five gallons of liquid. A container that is approved for flammable liquids is always the best.
Next, locate the closest gas station or convenience store that sells either regular diesel, off road diesel, or kerosene. Any one of these will work to get you going. Make sure that you never use any type of gas in your oil burner!
You will need to add at least five gallons to get the level of the liquid in the fuel tank over the oil intake pipe so that you can prime the pump. When you get the fuel poured into the tank you should wait at least ten minutes to let the fuel settle before you try to light the burner. Dumping the new fuel into the tank with very little liquid in there will stir up the sludge in the bottom of the tank. If you try to pull oil into the burner while the sludge is suspended you will then create more problems.
When you have the fuel in the tank you can begin to start the burner. If you have a TigerLoop installed in your fuel line then just by pushing the reset button you can purge the air. With a couple of clicks of the reset button you will be heating again. If you do not have a TigerLoop but the burner pump has a two pipe system the oil pump will usually purge the air, but it may take a few resets to get it going. If you have only a single pipe system, then look for my tip on bleeding your pump.
Running your oil burner out of oil will sometimes happen. You can fix the problem if you know what you need to do. Usually this always happens on the coldest night of the year or on that holiday weekend when a service call to the heating oil company will cost you an arm and a leg just to get you warm again. Now you can get your family warm till you can get the tank your oil tank filled at a reasonable cost.
Heating & Cooling Logo
Stopped heating yesterday...fan runs, but no heat... any parts available? Pretty sure is 120v ac.
Furnace Troubleshooting & Repairs ' HomeTips
www.hometips.com/repair-fix/furnace-problems.html
Nov 25, 2015 - If your heater doesn't heat or works poorly, this furnace repair guide will help you troubleshoot and fix typical furnace problems with step-by-step advice. ... If your furnace's motor runs but the blower doesn't move air, the belt that ..... a tune upbut couldn't really find any thing wrong . last night and today when ...
Furnace Not Blowing Air? A Furnace Troubleshooting Guide
asm-air.com/heating/furnace-not-blowing-air-troubleshooting/
Dec 1, 2014 - A furnace works by a very simple principle, it uses some type of fuel ...This series of heated coils (called a heat exchanger) has a fan ... Today we will address the most common causes of a furnace not blowing air, and what you can do tofix it. ... It seems like this would be a no-brainer, but I can't tell you how ...
Simple Furnace Fixes ' The Family Handyman
Jan 01, 2016 | Heating & Cooling
oil furnace only produces cool water intermittedly and only when heat is actively on
For clarity, a Furnace produces HOT AIR for heat while a boiler produces HOT WATER for heat. Just remember...boil = water. You said your "furnace" does not produce hot water for a shower and because furnaces do not product hot water unless they have some model that do???? Usually people with a furnace have a seperate hot water heater. People with boilers though can produce hot water for use as both their sinks/showers hot water and their heat (by heating water that goes through baseboards) in their house. I don't believe any furnaces produce hot water most of the time a furnace just produces hot air for heating. So figure out what you first have.
Having said that, I'll assume you have a boiler like I do and my Weil McClean(sp?) stopped working a while back and wasn't turning on to "boil" any water. I took apart the burner and there is a light sensing photo resistor as part of the controls. If this phto resistor goes bad, the boiler will not start. The resister is cheap, I think it was $8 but you have to know what you're doing to change it. So you may be better to call someone who can work on such equipment.
Boiler's themselves are not overly complex. Home heating oil is the same diesel fuel that you can buy in a gas station only the government has "oil" companies put a RED die in home heating fuel which is usually cheaper then Diesel fuel because diesel fuel is taxed to death. The reason they do that is so that if you try putting RED tinted home heating fuel in your truck and you get pulled over (because you're a trucker with and 18 wheeler and they typically do inspections of these trucks) you will be a huge fine if they see you're running home heating fuel and NOT paying your taxed by purchasing Diesel fuel. A little bit of background so you know the fuel you are dealing with here. So it's dieslel fuel without the tax you run in your boiler. Gasoline on the other hand is VERY explosive as you know, but diesel fuel (if you're ever tried to light it) takes some coaxing to get lit. When it's cold out, diesel fuel is very hard to light and that's why trucks use glow plugs. You don't need those in your home though.
But because diesel fuel/home heating oil is hard to light, it's sprayed as a msit into your boiler, so that it can light more easily.
But because it is a fuel, you should know what you're doing when messing with it. FInd out what you have, and then have someone work on the issue if you haven't already. I'm guessing you have had it fixed by now?
Mar 21, 2014 | Water Heaters
intertherm furnace..not working right
if i understand your problem description correctly when power is on but the furnace is not running you can smell burning dust and feel heat? first thing i can think of is possible a heater relay has gone bad keeping the heater on all the time but no fan...
Dec 12, 2007 | Heating & Cooling
3,163 people viewed this tip
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
