Tip & How-To about Watches
Pc can't start and beep in cpu.
When this problem, you cand do below step:
1st:remove all cable in cpu cabinate (power cable, monitor cable,etc.)
2nd:open cpu & remove ram
3rd: Clean it.
4th: push properly ram
5th: now 1st step opposite (Connect all cable)
6th:check it.
if your problem still not solved you can check other ram slot.
otherwise you can check ram other pc. if ram not work, it's problem in ram. otherwise you motherboard's ram problem. ok.
Watches Logo
I have a pulsar nx14-x003 watch with world time zone ect.. My problem is the digital time has dissapeared, the anolog time still works, as does the stopwatch ect.... When I edit the time the digital time reappears, but dissappears again when I leave edit mode. can anyone help?
Hi, maybe You just holded reset button at basic display mode. With 1st pressing and holding it for few secs You can make digital time disappear, 2nd holding makes disappear upper display, and 3rd time You are back with both displays on.. ;) Just bought them from eBay and lazy to read manual..its a nice watch indeeed :)
peace
Dec 30, 2012 | Watches
How do I set the digital time in my Surface 31874 watch?
When you press the Mode button:
1st press: FRI, SAT, SUN arrows flash. This is chronograph mode. Use START/STOP for stopwatch and RESET for split/clear.
2nd press: MON arrow flashes. This is where you set the alarm. Use START/STOP to advance number, and RESET to switch between minute and hour.
3rd press: TUE arrow flashes. This is where you set digital time. Seconds (in analog time window) flash first. Use START/STOP to reset seconds or advance number, and RESET to switch between seconds, minutes, hour, date day, and date month. Press mode again to exit. Have fun!
Oct 19, 2012 | Watches
How to change the time on Bulova Marine Star 100m. This is an old watch with 4 stems. 2 on each side. One is an on/off stem which is on the right side of the face.
1st: make sure the watch is set to "tme" , the botton dail display, press bottom right stem
2nd: pull out the bottom right stem ,
3rd: press the left top stem for increase time . i.e. 2:40 pm to... 2: 45pm
4th, or press the left bottom stem for decrease time: i.e. 2:40pm to .. 2:30 pm
5th: once time is good, then press in the right bottom stem,
May 03, 2010 | Bulova Marine Star 100 Meter Stainless...
Setting the independent hour hand on a Rolex Explorer II
It should be the 3rd position on the crown: 1st date, 2nd hour, 3rd time zone. And don't take it to a "jeler" like jamison said. If you cannot do this watch is fake.
Sep 20, 2008 | Rolex Explorer II 16570 Wrist Watch
Alarm
Alarm Setting:
1st: Press the mode button to go to the alarm screen.
2nd: Press the adjust button for the time to flash
3rd: (For the Hourly Alarm) You can adjust the time here while it is flashing by pressing the start/stop button. Cycle through this until you have the time you want. The setting will have the P in the left side of the screen for PM (night time).
4th: (For the Daily Alarm) Do steps  1-3 once the time is flashing use the Mode button to cycle through to the date field of the watch. Once it is flashing you can use the Start/Stop Button to chose which date Month/Day, after chosing the month just press the Mode button once more to go to the day field.
Jan 05, 2007 | Casio DW9052-1V Wrist Watch
188 people viewed this tip
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
