Tip & How-To about Washing Machines
Washer Leak - Top Loader
This advice is for trying to determine the location of a leak on a Whirlpool manufactured top loader. Just follow these steps to access the interior to determine where the leak may be coming from:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
If the leak is coming from the front of the washer, most commonly this is caused by a leaking drain pump. The pump is located in the front directly below the wash tub. The pump is not serviceable and must be replaced if it is damaged.
Some other items to consider:
1. Check your fill hoses to ensure they are tight and not leaking. What can often appear as a washer problem, may be a loose hose.
2. With the washer case removed, check the area UNDER the wash tub. If the leak is coming from the center above the transmission, the tub seal may be leaking.
3. Inspect the wash tub for any cracks. If the tub is cracked and its not serious, you may be able to get by with some marine epoxy to reseal it. If the crack is significant, a new tub will be required.
4. If the water is gushing out of the bottom of the washer, check the air dome on the lower right hand side of the wash tub. This is a small plastic air hose that runs from the wash tub all the way to the pressure switch. If this hose comes loose, the washer will start to leak as it fills. Simply reattach if it comes loose.
NOTE: The ends on the air hose can become stretched over time. If you have enough slack in the hose, you can snip off a small portion of the end and reattach it to make sure it fits snug. If not, attach the hose to the air dome and place a zip tie around it where it connects to the air dome fitting. Make the zip tie snug enough to keep the hose from slipping off. Do not overtighten.
If you need an illustration of your washer and components, searspartsdirect.com, appliancepartspros.com, or pcappliancerepair.com usually have some excellent exploded view diagrams that you can refer to.
If you determine the pump is damaged and needs replaced, the following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
To reinstall the washer casing, follow these steps to ensure you get the case correctly placed and secure on the frame:
1. With the lid of the washer open, grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
Read through everything thoroughly before beginning any repairs. If you have any questions, or require additional assistance, please let me know. I hope this information is helpful.
Washing Machines Logo
slight leak from under the washer
If your TOP LOADING Whirlpool manufactured washer is leaking, the following link explains how to remove the exterior washer case in order to accurately inspect the washer interior components for the source of your leak:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
If the leak is more like a constant drip, a common source of leaks with Whirlpool manufactured top loaders is a leaking drain pump. These pumps are not serviceable and if damaged, must be replaced. The following link explains how:
Don't forget to check all drain hose connections under the washer and the center tub seal.
Replacement parts (if required) can be purchased at any of the following websites:
searspartrsdirect.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
Aug 24, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
my whirlpool washer leaks water
repairclinic.com
Jul 31, 2010 | Whirlpool LSR7333 Top Load Washer
tiny leak at front of machine
Is this a FRONT LOADER? Or, a TOP LOADER?
The following link explains how to access and inspect the interior of a FRONT LOADER and what common sources of leaks to look for:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
The most common source of front loader leaks comes from the door bellow (gray rubber seal). A routine inspection around the perimeter of the door for rips or tears will tell if the bellow needs replaced. If the bellow requires replacement, the following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If this is a TOP LOADER, the following link explains how to access and inspect the interior for common sources of leaks:
The most common source of leaking on a TOP LOADER is the drain pump. These pumps are not serviceable and if found to be leaking, need to be replaced. The following link explains how:
Whatever style washer you have, make sure you read through the links provided and follow the steps on how to properly access your washer interior so you can get an accurate view. Make sure you check all tub seals, dispenser hoses and drain hoses as well.
Replacement parts (if required) can be purchased from any of the following websites:
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have questions, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
Jun 22, 2010 | Washing Machines
washer is leaking from under machine checked all hoses and drain connections and there were no leaks in them.
repairclinic.com
If you have questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Jun 08, 2010 | Washing Machines
My Whirlpool Ultimate Care II washer is leaking under the right front. Any ideas?
If this is a Whirlpool manufactured top loader, you will need to remove the exterior washer case in order to accurately determine where the leak may be coming from. The following link explains how to access and inspect your washer for leaks:
In the majority of cases with a top loader, the water pump begins to leak. These pumps are not serviceable and require replacing if damaged. The following link explains how:
repairclinic.com
All these sites are reputable and have great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
Follow the tips in the link(s) provided and make sure you inspect all hoses and tub seals as well.
If you have any questions, please post back with your and let me know. I hope you find this information helpful.
Apr 17, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
4,741 people viewed this tip
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
