Tip & How-To about Washing Machines
Door Jam on Kenmore Elite and Whirlpool Duet Washers
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement. You can click on the following link if you need step-by-step instructions on how to replace the door latch:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
I hope this information is helpful.
Washing Machines Logo
My front loading washer door will not open. How can I open it?
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
how do I unlock my frontload whirlpool duet washer
Aug 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
front door would'nt open on my kenmore tumble action washer model #417
Jul 21, 2010 | Kenmore Elite 45986 Front Load Washer
my kenmore elite door will not unlock
Sep 25, 2009 | Kenmore Elite 45986 Front Load Washer
584 people viewed this tip
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
