Tip & How-To about Dryers
How to Install a Dryer Belt on Kenmore Elite and Whirlpool Duet Dryers
This advice is for dryer belt replacement on most Kenmore Elite and Whirlpool Duet model dryers. If in doubt, please provide me with a complete model number of your dryer and I will determine if these instructions apply.
In order to replace the drive belt on a Whirlpool Duet/Kenmore Elite dryers, you need to perform the following steps:
1. UNPLUG the dryer before servicing. Dangerous voltage is still present inside the dryer even when it is turned off.
2. Open the door and remove the lint screen. IMPORTANT: You will not be able to remove the air blower cover with the lint screen in place.
3. Remove the lower toe panel located directly below the door by loosening the screws under the bottom front edge. With the screws removed, the panel will drop down, then come off.
NOTE: Propping the two front feet of the dryer up can provide better access to the screws (a 2x4 works well).
4. Disconnect the auto dry sensor plug (usually yellow wires with a white plug to the right of the blower assembly) and any ground wires that may be connected to the front panel.
5. Remove the air blower cover by locating and removing the mounting screws.
NOTE: This is a good time to clean the blower fan housing, squirrel cage motor and dryer interior cabinet.
6. Remove the top panel of the dryer by locating and removing the screws holding the panel in place in the rear of the dryer. With the screws removed, the panel will slide back, then come off.
7. Locate the two screws that hold the operator console in place. There should be one on each side under the top panel. Remove the screws and carefully lift the panel straight up.
NOTE: You do not need to disconnect the ribbon cables. Carefully lay the console across the top of the dryer out of the way.
8. Disconnect the door switch connector plug and remove the dryer front panel by locating the four screws that hold it in place. Loosen the two screws along the bottom of the panel and leave in place. Remove the top two screws and lift up and turn the whole front panel slightly counter-clockwise to release the drum supports from the dryer drum.
NOTE: Make sure the dryer door is closed when removing the front panel to avoid damaging the door hinges.
9. You can leave the drum in place to install the new belt. Loop the belt onto the dryer drum with the ribbed side facing the drum. Reach in behind the air blower with both hands and pull the idler pulley to the right with your right hand to release the tension. With your left hand loop the belt over the drive motor pulley, then release the idler pulley making sure the belt rests on the pulley. You should feel the belt tighten with tension.
NOTE: If you need further clarification on how to properly route the dryer belt you can go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, locate the "Dryer Belt Diagrams" link under the Special Features section. Refer to diagram K.
10. Reinstall the front panel by turning it slightly counter-clockwise and aligning the front drum supports under the front of the drum. Once the supports are under the drum, turn the front panel clockwise and lift up, placing it on the bottom two screws. Reinstall and tighten the top two screws.
11. Reinstall the door switch connector plug and reinstall the operator console. Use caution not to put too much stress on the ribbon cables.
12. Reinstall dryer top panel.
13. Reinstall air blower cover and reconnect the auto dry sensor and ground wire.
14. Reinstall toe panel by inserting the top portion first and pushing up. Push lower portion of the panel in place and reinstall screws.
I know this may seem like a lot, but its actually fairly simple if you follow the steps provided. The trickiest part will be getting the dryer belt installed correctly and removing and reinstalling the front panel. If you have any questions, please let me know. I hope this helps you.
Dryers Logo
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Drive Belt Installation on a Whirlpool Duet or Kenmore Elite Front Loader
    Thanks for this helpful information! I noticed that the drum pulley is very wobbly, yet the holding bolt is tight, is this normal? Should the pully be firm and not wobble or rotate?
    Sep 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Is this the same instructions for the Whirlpool GEW9200LWO dryer?
    Sep 30, 2009 | Kenmore Elite HE4 Electric Dryer
    control locked light is on. Have replaced control board but control still locked
    This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
    This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
    Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
    Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
    Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
    Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
    These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
    NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
    If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
    Hopefully, this simple advice will save you an expensive service call.
    May 28, 2015 | Whirlpool GEW9250 Electric Dryer
    Kenmore Elite & Whirlpool Duet Washer and Dryer Control Panel Locked
    this was helpful! took three screws out, loosened a flex clamp and blew through the tube to free the impeller. saved a service call!
    Jun 27, 2009 | Kenmore Elite 45986 Front Load Washer
    465 people viewed this tip
    Top Dryers Experts
