Tip & How-To about Computers & Internet
How to adjust the visual effects in order to make your Computer faster...
There are a lot of tuneup utilities to do with for more reliable and faster loading with your operating system like windows. These commonly used to adjust some settings for the best performance for your visual effects, memory usage & processor scheduling.
In your System Properties as you can see the Advanced Settings then your can adjust what is best for your Computer.
Computers & Internet Logo
need to fix stack and slow downloading need to clean
Its a very common error in windows Xp. You need to optimize your PC to its best performance. Use a system utility software like ReginOut to to sppedup your PC & fix operating systems and windows registry errors.
Dec 26, 2011 | Microsoft Windows XP Home for PC
Hi I have win 7, CCleaner, kaspersky 2011 & tuneup utility 2011 the tuneup says "prefetch data deleted" pls help me how to troubleshoot this problem
It is absolutely safe to delete the Prefetch Data. Each time you turn on your computer, Windows keeps track of the way your computer starts and which programs you commonly opened. Windows saves this information as a number of small files in the prefetch folder. The next time you turn on your computer, Windows refers to these files to help speed the start-up process. You may also change the setting of Tuneup Utility not to clear the prefetch data. Rest assure that it is safe either way and doesnt have much impact on high speed systems.
Let me know if any further clarification is required.
Good Luck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 15, 2010 | Computers & Internet
have ran tuneup utililites and have a message saying the files in the prefetch folder have been deleted by me or a program its not me so what program would delete these files as the pc is permanantly heavily defragmented and running slow.no malware or virus on the pc that i am aware of as i have checked with malware bytes and avira
Tuneup utility progs are great if you know what you are doing, unfortunately most people don't..
The prefetch folder loads part of a prog into the system memory so that it can be opened quicker hence the term. This will slow the PC down if there is not enough memory installed to cope.
Malwarebytes is a very good prog provided you remmber to uopdate the database before the scan. Avira I cannot comment on never having used it but if in doubt you can run a virus scan from here
http://housecall.trendmicro.com/uk/
To check which preogs are running from startup, clear registry errors etc use this free app
http://download.cnet.com/ccleaner/
Aug 23, 2010 | Computers & Internet
96 people viewed this tip
David Payne
David Payne
