Tip & How-To about Washing Machines
Replacing Water Inlet Valve on Whirlpool Washers
This advice is for Whirlpool manufactured TOP LOADING washing machines. If you suspect you have a defective Water Inlet valve (also known as a FILL valve or MIXING valve) it can easily be diagnosed by performing the following steps:
- First, make sure the water taps are turned on all the way, and the fill hoses are not kinked in anyway. If everything checks okay, proceed to the next step.
- Now, turn the water taps off, disconnect the fill hoses from the back of the washer and place them in the wash tub. Turn the taps back on and make sure you have proper and forceful water flow (minimum water pressure should be 10-25PSI).
- Check the sediment screens on the Water Inlet valve on the back of the washer. Sometimes these screens will clog with rust or sediment and prevent water flow. Cleaning with some distilled vinegar works well.
If you’ve attempted all the steps above, but still have no luck, more than likely the inlet valve is bad and requires replacement. Please, read all instructions thoroughly BEFORE attempting. This is a simple repair that any “Do-It-Yourselfer” can accomplish. Follow the steps provided:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
7. The inlet valve is located on the back panel with two or more sets of electrical connectors attached to it. The connectors are usually color-coded to indicate which valve is HOT and which valve is COLD (In the case of a Mixing Valve, you may have additional electrical connectors). Remove the connectors and check the contacts for corrosion. Sometimes a good cleaning can restore a valve solenoid to working order. (You may want to label the connectors, if necessary, to ensure you know how they go back on).
8. Disconnect the small rubber water hose(s) attached to valve with a pair of pliers to release the hose clamps. Inspect the hose(s) for any evidence of cracking.
9. With the water hose(s) removed, loosen the mounting screw(s) and the inlet valve comes off.
10. Re-install new inlet valve following these steps in reverse order. Pay careful attention to make sure you correctly connect the HOT & COLD electrical connections (RED is usually the HOT water side). Make sure all hoses are fitted back in place and the hose clamps are snug.
11. Re-install washer case. With the lid of the washer open, grasp the case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
12. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
13. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
14. Reinstall console.
I hope these instructions are found to be helpful.
Washing Machines Logo
what dose a FL code mean on whirlpool cabrio platinum
I will try and help for some reason Whirlpool likes to flip letters around which differ from the service manual FL would be an LF long fill or is it a F1 the model doesn't show in the Whirlpool data base nor parts suppliers I suspect wtw6600sb1 does the machine from initial start fill correctly then wash if so we can eliminate the pressure switch and hose after wash cycle unit should drain then fill with rinse water if the inlet valve does not let water into the machine to satisfy the pressure switch the control times out and flashes a long fill code this unit has a log valve system possible you have a bad inlet valve on the bank of valve or a bad control not outputing voltage to the valve, hope this points you in the right direction
Jan 14, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
cold water rinse takes hours to fill
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.Replace the water inlet valve with this part.
Dec 26, 2010 | Whirlpool LSR5132PQ Top Load Washer
Water flow into washer will not shut off
It could be the valve or the fill sensor. You can Google the washing macine brand and it will give you a diagram of what parts the washing macine has and does Also try RepairClinic.com. .
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool top loader
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
4,794 people viewed this tip
Top Washing Machines Experts
