Tip & How-To about Washing Machines
Basic Washer Installation Advice
Here are some installation tips for washing machines. This is meant to provide BASIC guidance and not meant to deviate from any installation criteria that may come with your washer. Follow your manufacturer’s recommendations if they differ from those outlined here:
- Water pressure requirements should be a minimum of 10-25 psi to prevent fill valve leaks and proper fill rates. A minimum pressure is required to keep the fill valves closed when not in the process of filling. If the water pressure is too low, you may experience symptoms of water filling in the wash tub when not in use and/or longer fill times.
- The drain line should be capable of handing 17 gallons of water per minute. If not, you could experience overflows from the standpipe during the drain cycle.
- The standpipe should be 2 inches in diameter, be a minimum of 34” from the floor to prevent siphoning, and should not exceed 72 inches in height. DO NOT seal the top of the standpipe, or place the drain hose too far down into the pipe. This can also cause siphoning. 4 to 6 inches is sufficient when placing the drain line into the standpipe.
- The operating temperature for the washer should be above 60 degrees F. It is not safe to place a washer in an environment where it is allowed to freeze. Residual water in the drain lines, fill hoses and pumps could freeze and damage the washer. This is something to consider when placing a washer in a location outside the home like a garage.
- The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
- When leveling, make sure the washer is level SIDE-TO-SIDE and FRONT-TO-BACK, and that you place the washer on a FIRM foundation. Weak flooring is the number cause of washer vibration and out-of-balance problems. If the flooring flexes when the washer is in the spin cycle, the washer will vibrate, no matter if it is level or not (this is particularly a problem with front loaders). If you do not have an alternative, the flooring can be firmed up by placing a 4 x 8 sheet of plywood (at least ¾ inch thickness) under the washer to help distribute the weight more evenly.
I hope these tips are informative and help prevent some of the more common washer problems that can easily be remedied by double checking your installation.
Washing Machines Logo
The door seal in my kenmore elite HE3 is ripping...is it replaceable?
Yes, it is. This is a fairly simple repair that anyone can do with a little guidance. The following link explains step-by-step how to install a door bellow on a Kenmore Elite front loader:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Read through the link provided and let me know if you have any questions.
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are very heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time. Thanks to user DGBG for the helpful tip.
If you would like some helpful exploded view diagrams of your washer that you can reference, you can use any of these web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
Just use your model number to begin your search criteria.
If you have any questions, please let me know. I hope this helps you.
NOTE: These door seals do wear out and require replacement from time to time. However, overloading the washer to the point where items get caught in the door area can contribute to premature wear and tear.
Nov 17, 2009 | Kenmore Elite 45986 Front Load Washer
During rinse cycle, water is running out of the door
Inspect the door bellow (seal) for any rips or tears. It may be worn or loose and require replacement. This is a fairly simple repair that anyone can do with a little guidance. The following link explains step-by-step how to install a door bellow on a Whirlpool Duet front loader:
Nov 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
can i replace the boot seal myself
Yes, you can. This is a fairly simple repair that anyone can do with a little guidance. The following link explains step-by-step how to install a door bellow on a Kenmore Elite front loader:
Nov 12, 2009 | Kenmore Elite HE5t Washer
How do you install rubber door seal and the metal ring with spring attached on the whirlpool duet
The following link explains step-by-step how to install a door bellow on a Whirlpool Duet:
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are very heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time. Thanks to user DGBG for the helpful tip!
Oct 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
224 people viewed this tip
Top Washing Machines Experts
