Tip & How-To about Cycling
Cut brake/ gear cables w/o fraying the ends
If you don't have the nifty cable cutter tool that the bike stores sell, try using a good pair of tin snips. A sharp pair of snips will cut through the cable much more neatly than than the old standby wirecutters do. The teeth on the snips' blades hold the cable while it cuts preventing the mashing that frays the end.
Cycling Logo
My daughters 2008 Lancer positive battery terminal is so corroded that the main bolt won't come out of the cables for it to be replaced. We tried baking soda to get rid of most of the acid but the bol
You might try a battery cable terminal removal tool sold at most auto parts stores. This looks like a mini gear puller that grabs the bottom of battery cable terminal and has a screw action stem that pushes against the battery post . Tool I think will be about ten bucks..
Dec 29, 2014 | 2008 Mitsubishi Lancer
Are bolt cutter blades really sharp?
A pair of new or freshly sharpened bolt cutters will be sharp enough to cut through skin if you run your finger along the blade. Never run your finger along the blade to check for sharpness.
Nov 14, 2013 | Cutter Tools
front brake broke, wire to right side gear shift severed, need estimate on repairs or parts and to fix.
A bike shop will charge $15-20 for brake cables, but when you replace any cable you need to replace all of the rest too. It can be tricky and requires a $40 tool as well so it is prabablly best to leave to the bike shop. So in all it would cost over $120 to do it yourself and probably about 75-100 for the bike shop to do it. (unless you have the CORRECT BIKE SPACIFIC CABLE CUTTING TOOL not a regular cable cutter). If you have the cutters then it will be cheaper to do yourself.
Jul 22, 2011 | Mongoose 2008 Teocali Comp Mountain Bike
how do i cut cotton on an elna stella? normally the cutter is up at the base of the needle but i cant find mine.... thanks!!
There should be a little **** in the back of the pressure foot bar that you cut the thread on. It normally is about an inch above the pressure foot attachment screw running horizontally.
Elna also bought out a a little black pressure foot screw/combination thread snip that replacded the silver thumb screw holding on the pressure foot shank which serves the same purpose. You wind the thread around it on the left side into a spring loaded crack and pull, it cuts and holds the two ends.
Failing that, a cheap pair of thread snips is another way to solve the problem.
Jun 08, 2011 | Elna Sewing Machines
How do you replace the top radiator filler hose assy? The hose clamps seem to be one time use only.
I'm not sure what kind of clamps are on there, but they can be replaced with a standard hose clamp from any auto parts store. If you can't get them to come apart with a screwdriver you might have to use a snipper of some sort to cut them off. One time use ones typically have some sort of crimped piece that sticks up. If you use a cutter to cut that off they usually come right apart. If that doesn't work you can use a razor blade to cut the hose off of the fittings right next to the hose clamp. This should give you enough room to wiggle the hose clamp off or at the very least work a tin snips under the edge and cut it. Sometimes hoses get fused to the radiator and thermostat housing too, just wiggle a small screwdriver under them and it should break it loose after a little gentle prying.
Nov 12, 2009 | 2002 Dodge Durango
169 people viewed this tip
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
