Tip & How-To about Computers & Internet
How to search for anything faster.
Open new tabs faster for Firefox, IE8 and Safari and Chrome by highlighting the keyword(s)/topic from a current page you are viewing then, while pressing ctrl key, press keys C, T, V and then release ctrl key and press 'enter' key.
Preferably, change your homepage to Google. Google gives better results than other search engines.
Narrow your search by adding + sign to the highlighted/copied/to-be-searched keywords and the additional keywords you're looking for. This way, you'll see the desired search results easily.
Computers & Internet Logo
make Google my homepage
Chrome:
  1. Click the Chrome menu snp_2696434_en_v1 on the browser toolbar.
  2. Select Settings.
    • Add the home button to the browser toolbar
      Homepage button is off by default. Select the "Show Home button" checkbox in the "Appearance" section to show it on the browser toolbar.
    • Set your homepage
      When the "Show Home button" checkbox is selected, a web address appears below it. If you want the Homepage button to open up a different webpage, clickChange to enter a link. You can also choose the New Tab page as your homepage.
IE:
  1. Make sure you've closed all open tabs, then open Internet Explorer for the desktop.
  2. Tap or click Tools, and then tap or click Internet options.
  3. Under the General tab, enter the web address of your new home page, and then tap or click Apply.
FireFox:
  1. Open the website you want to set as your home page. If you want a blank home page, open a new tab.
  2. Click the icon to the left of the web address, drag it to the Home button, and release.
  3. Click Yes to set this as your home page.
Safari:
1. Click on Safari in your Safari menu, located at the top of your screen. When the drop-down menu appears, choose Preferences.
2. Select General from the Preferences menu, which is now overlaying your browser window. Once General is selected, you will notice a section labeled Home Page in the main window of the Preferences dialog.3. Directly to the right of the "Home Page" label is an edit field containing your current home page URL. In the example below, Safari's current home page is http://www.apple.com. To modify this address, simply erase the contents of the edit field and replace it with the desired web address.
4. Directly below this edit field you will see a button labeled Set to Current Page. Clicking this button will change your home page setting to whatever page you are currently viewing within the Safari browser.
5. Once you have completed your changes, close the Safari Preferences dialog by clicking the red circle/x located in the top left hand corner of the box.
Sep 19, 2013 | Computers & Internet
how do I delete bing from my computer?
Below are instructions for setting your homepage in the big 3 Mac Browsers:
Chrome - Open Chrome, go to top menu, choose Chrome-Preferences-Settings tab-On Startup area then choose Open a Specific Page... and set the page
Safari - Open Safari, go to top menu, choose Safari-Preferences-General then set your homepage there
Firefox - Open Firefox, go to top menu, choose Firefox-Preferences and set the home page under the General-Startup area.
Oct 12, 2012 | Apple 27 iDesktop Computer (Z0JP0004) Mac...
IE8 will load up when you start to navagate to another page error pops up that it needs to close. another program has caused the problem.
If you like IE8 that's fine but I would try another browser like Firefox, Safari, Opera, or Google chrome, all are very good browsers and in my opinion far better than IE8.
Feb 01, 2011 | Computers & Internet
how do i change my home page? i want it to gateway
hi
Internet Explorer for Windows
1. Browse normally to the web page you want as your home page.
2. Pull down the "Tools" menu of Internet Explorer.
3. Select "Internet Options."
4. The "General" tab appears.
5. You'll see the "Home page" box at the top.
6. Click the "Use Current" button in that box.
7. Click "OK." \
8. Close and open Internet Explorer. You should see your new home page.
Firefox for any operating system Changing your home page in Firefox is easy. Just follow these steps:
2. Pull down the "Tools" menu of Firefox.
3. Select "Options."
4. Click on the "General" tab, if it is not the first to appear.
5. You'll see the "Home Page" box at the top.
6. Click the "Use Current Page" button in that box.
7. Click "OK."
8. Close and open Firefox. You should see your new home page.
Safari for MacOS X
Changing your home page in Safari isn't tough either:
2. Pull down the "Safari" menu.
3. Select "Preferences."
4. Click on the "General" tab.
5. Note the "Home page:" field and the "Set to Current Page" button beneath it.
6. Click "Set to Current Page."
7. Click the red "close" button in the upper left corner of the preferences dialog.
8. Close and open Safari. You should see your new home page.
Opera
Opera changes the home page in pretty much the same way as the rest:
2. Pull down the "Tools" menu.
3. Select "Preferences..."
4. The "Preferences" dialog box appears. Click on the "General" tab.
5. Note the "Home page" field and the "Use Current" button to the right of it.
6. Click "Use Current."
7. Click "OK."
vote me if you have your solution
Oct 25, 2010 | Computers & Internet
cannot access farmville.Error handler already exists
Zynga games are designed to be used with most browsers, however there are several documented issues surrounding Internet Explorer 8 (IE8) and Flash Content.
If you are using IE8 we suggest that you try a new browser such as Firefox 3+, Safari 4, or Google Chrome. Internet Explorer v.6 or 7 should also be acceptable.
Firefox is available here:
http://www.mozilla.com/en-US/firefox/firefox.html
Safari is available here:
http://www.apple.com/safari/download/
Chrome is available here:
http://www.google.com/chrome
Dec 04, 2009 | Facebook Social Network
114 people viewed this tip
David Payne
David Payne
