Tip & How-To about GPS
How To Prolong Your GPS' Battery Life
Are you tired of having to keep your GPS plugged into the car for the entire duration of your drive? Does it die out instantaneously after removing it from it's jack? If it does, there nothing you can do to fix it because the battery had over heated and lost its battery life tremendously. I can only say that you would need to purchase a new one.
However, if your GPS doesn't die out right away, here's your chance to start prolonging its life. First, let it completely die out by turning it on, and leaving it on until it the batteries run out of charge. Second, plug the dead GPS into either a house outlet, or a car jack (if you are using the car jack, make sure the car is on!!!). Third, wait for the GPS to reach full capacity, but DO NOT let it overcharge, it kills the battery. So I recommend checking on the charging GPS periodically at even intervals of your choice. When it is done, just unplug it, and it is good to go.
NOTE: Do not charge the GPS in while in use.NOTE: If the battery is low as you are driving, turn it off and plug it in to charge.Explanation: This is why the steps above the notes are to be taken to prolong the life of your GPS' battery. 1 Complete Charge + 1 Complete Drain = 1 Charging Cycle
Thanks for reading my tip!
GPS Logo
why my 2007 suzuki forenza keeps dieing on me when i'm driving
keep next out of front tire area..... works pretty good.
heheheheehehehehehe
my car stalls. that it?
stalling has 50 reasons,
one very top reason is never getting a tuneup, ever.
at the least spark plugs..... or do the 60k mile list.
May 19, 2015 | 2007 Suzuki Forenza Sedan
Prolong Your GPS Battery Life
Thanks a ton for this post--it helped me out a lot! I am looking forward to a longer battery life from my GPS. I think this also works for almost any electronics, like laptops, phones, ipods etc. So your post sure helped out a lot of people.
Dec 04, 2009 | GPS
My battery keeps dieing on my 1994 accord, what could the problem be?
If you can drive it for a long time then it is not the alternator. The battery has a short charge duration and it is old. There is a parasitic drain on the system that is draining it when it is not running.
Sep 14, 2014 | 1994 Honda Accord
what is the cause of continual thumping (appears to be coming from back of car) and violently shaking?
Many times, rear tires that are out of round or severely cupped or feathered, or that are out of balance can create this type of issue. My first recommendation would be to have them and the wheels on the rear of the car inspected. There may not seem like there is much wrong visibly if you look at just the tread of the tires, but a good tire tech can spin them up and give you some solutions, and the inspection itself is inexpensive. Hope this helps.
Jun 19, 2012 | 1997 Nissan 200SX
139 people viewed this tip
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
