Tip & How-To about Kitchen Appliances - Others
Fault finder Home electric main fuse
If the fuse in your home is geting down on main fuse. and you dont now wher the fault is. Check: 1 take all fuses down then take the main fuse up. 2 take one after one of the other up then you find the fault becaus the main is geting down when you com to the fault fuse virring. 3 take out all component of the grid on this virring/conection se if the main fuse stans or fall.if it stand, plug one and on into the grid. then you can find the fault component and fiks that/or bye a new one. God luck.
Kitchen Appliances - Others Logo
98 town car my brake lights both turn signals work my hazards work, but my running tail lights don't work
Inside your instrument fuse panel look for fuse #31 which powers up the light control module and the main light switch, also while there be sure and check fuses 1, 3, 5, 7, and 9 to be sure they're not blown.
Let me know if this helps.
Rodney
Jun 14, 2011 | Lincoln Town Car Cars & Trucks
20litre fsi, Epc light comes on when coolant temp gets to 90, then vehicle cuts out, fault code shows fuel pressure regulation control lower limit exceeded P1020, wher might the fault lie?
car systems r so complicated-dont go buyin new parts till u hookit to a tech ll that runs a data stream--hav u done regular tuneups and fuel filter change
May 19, 2011 | 2002 Audi A4
my brake lights does not work on my saturn do they have a fuse and wher would that be
prolly a fuse if both dont work. check your manual to find out where the fuses are
Apr 01, 2009 | 2000 Saturn SL
685 people viewed this tip
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
