Tip & How-To about Computers & Internet
Upgrading to Windows 7?
Many people are hurrying to upgrade their Windows XP or Vista computers to Windows 7.
My advice is simple. Do a little bit of research first to make sure your computer and other peripheral equipment, especially printers, have drivers available for the new operating system. There is no greater frustration when you think that you are making an improvement and your sound or your printer doesn't work after the upgrade.
Nearly all computer manufacturers have support sites where you can check to see if the drivers are indeed available. For example: If you have an HP or Compaq go to HP Support and enter your model number and follow the links to Software & Driver Downloads. Click on Windows 7 when you get the OS choices and it will let you know if drivers for that equipment are available.
I would also suggest that when you find the drivers for your computer and equipment, that you go ahead and download them to your computer and burn them all onto a CD/DVD so that when you do upgrade they will be right there at your fingertips and the process will go smoothly.
Happy Upgrading!
Computers & Internet Logo
Can Vista Home Premium be upgraded to window's 7?
      If you're running a 32-bit version of Windows Vista, you can only upgrade to a 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only upgrade to a 64-bit version ofWindows 7. Otherwise, you'll need to use the Custom option to install Windows 7.
      Upgrading from Windows Vista to Windows 7 - Windows Help
      windows.microsoft.com/.../windows7/.../upgrading-fro... Microsoft Windows
    Feedback
    windows.microsoft.com/.../windows7/.../upgrading-f...
    Microsoft WindowsIf you're running a 32-bit version of Windows Vista, you can only upgrade to a 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only upgrade to a 64-bit version of Windows 7. Otherwise, you'll need to use the Custom option to install Windows 7.
    How To Upgrade from Vista to Windows 7 Home Premium ...
Feb 08, 2016 | Computers & Internet
Can this model be upgraded from xp 32 bit to windows 7 64 bit with 2.5 gb of memory?
Yes you can however HP only supports Windows XP (32-Bit), Windows Vista (32 and 64 Bit) No official support for windows 7.
However Most modern PC's will run windows 7 and most drivers are available. Upgrade at your own risk.... There might be some drivers that you wont find and may cause problems with your PC.
But why upgrade to 64bit if you are not upgrading memory to 4GB+?
See Windows 7 system requirements Microsoft Windows
May 04, 2014 | HP Compaq Presario SR1910NX (EX310AA) PC...
Toshiba L40 constant disk activity
Did you check if your computer is capable of running Windows 8 comfortably? Have you followed the upgrade procedure? 2 GB memory seems rather too little. What was the original Windows version? XP, Vista, Windows 7. Was the original OS 32 bits or 64 bits?
Nov 03, 2013 | Toshiba Satellite Computers & Internet
I could not upgrade neither windows XP, Windows 7 of this Product Model: GT5662. Would you assits? Thanks.
Hello kelvinvu, according to the information that I gathered from this computer model, it has Windows Vista 32 bit home premium installed on it. Windows XP is an older operating system so you can't "upgrade" to it. You could however install a fresh copy (more likely completely erasing all your previous information on vista and data files) or you could upgrade to Windows 7. Since you are using "Windows Vista 32 bit home premium", you have to upgrade to "Windows 7 32 bit home premium" or better. So if you were trying to "upgrade" to Windows 7 Home Basic, it will not allow that since it considers that a downgrade in the Operating System. You should actually be able to pop in the Windows 7 Home Premium CD while vista is running and start the upgrade process pretty painlessly that way. Just access the CD and walk through the menus for upgrading Vista to Windows 7. As a reminder, you must use the 32 bit discs. If you try and use the 64 bit discs (a different operating system as far as windows is concerned) you will have to go through the same process of installing a new version of windows (not upgrade). I hope this has solved your specific problem kelvinvu, have a great day!
May 15, 2011 | Gateway GT5662 Desktop PC
Acer Aspire x3200 vista 64 bit upgraded to windows 7 32 bit. Coprocessor now has a yellow exclamation make. I have tried to update the driver but it cannot find any.
better wa y is to downgrade your OS back to Vista 64bit, the problem with windows 7 is that most of the drivers operational to xp and vista are still not supported by windows 7.
Oct 31, 2009 | Acer Computers & Internet
146 people viewed this tip
David Payne
David Payne
