Tip & How-To about Computers & Internet
Wireless security issue. How to secure the network ?
To secure the wireless network or to change any settings on the router you will need to access the router set up interface.
Open the set up interface of the router . Make sure that your computer will be connected to the router with the Ethernet cable.
Click here for step by step instructions
Onceyou open the set up page of the router , you will find the place tochange the wireless settings of the router. In case of Linksys wirelessrouter , you will see the Wireless Tab at the top.
SSID :It is the name of the wireless network. This name will be shown on yourwireless computer or the wireless device so that you can identify yourown wireless network. All the routers come with their factory defaultsettings. For example , the Linksys router will come with the Linksysnetwork name.
It will be better to change the wireless network name.
Wireless Security
Change the security mode to WEP.This security type is supported by all the operating system. Whenchange the security mode to WEP, you will find the Network key box totype the network key. Do not type anything in the Passphrase box. Typeyour network key in the Key 1 Box. If you set the encryption to 65bits, your network key will be 10 digit hexadecimal number. that meansyou can use the combination of 0,1,2,3,4,5,6,7,8,9 and lettersa,b,c,d,e,f only. remember it should be exactly 10.
If you set theEncryption to 128 bit, your network key will be the combination of 26digits. You will need to remember the network key.
WPA
This is one of the most secured type of encryption.
Openthe set up interface of the router. Change the wireless security modeto WPA personal. You will find the passphrase box. in this box you cantype any password for your wireless network. The password should be thecombination of number and letters and it should be 8 or more than 8characters.
This security type is supported by WINDOWS XP SP2 and above Operating system.
WPA2
This is one of the highly secured type of encryption.
Openthe set up interface of the router. Change the wireless security modeto WPA personal. You will find the passphrase box.In this box you cantype any password for your wireless network. The password should be thecombination of number and letters and it should be 8 or more than 8characters. Keep the Algorithm to TKIP.
This security type is supported by WINDOWS VISTA and above.
Once you change the wireless settings on the router , try to connect to the new wireless network .
Computers & Internet Logo
Wifi works and all but keeps having my two phones put the password in every half and hour. I don't have the disc for it so can't really set it up just connected it to my charter modem.
Try this please:
  1. eHow
  2. Internet
  3. Wireless Internet & Network Hardware
  4. Netgear Wireless Routers
  5. How to Access Netgear Wireless Router Settings
X Must See: Slide Shows
How to Access Netgear Wireless Router Settings Xno-user-image.gif Ryan Bauer
Ryan Bauer is a freelance writer located in Ozark, Missouri. He has written numerous articles and books, including "How to Improve Your Credit Score 100 Points in 100 Days." Bauer is an experienced automotive mechanic and computer technician.
By Ryan Bauer, eHow Contributor , last updated February 24, 2012
72955587_xs.jpg Wireless routers connect computers to a network without the need for network cables.
Wireless routers are used to connect computers into a network without running network cables throughout your home or office. Netgear wireless router settings must be changed using the router's Web-based interface. Any computer that is "hard wired" with a network cable to the router, rather than on a wireless connection, can be used to access the router. From the Settings menu, options such as "Encryptionicon1.png," "Network setup details" and "Passwords" can be customized.
Other People Are Reading
Instructions
    • 1
      On a computer that is connected to the routericon1.png with a network cable, open any Web browser, such as Internet Explorer or Mozilla Firefox. In the address bar, type "192.168.0.1" (without the quotes) and press "Enter." This will bring up the login prompt for most Netgear wireless routers. If that doesn't work, try "www.routerlogin.net", "192.168.0.5", or "10.1.10.1" until the login window appears.
    • 2
      Type "admin" in the Username field, type "password" in the Password field and click "OK." If the password fails, try "1234," "Password" with a capital "P" or "admin". Once you enter the proper credentials, the settings screen will open.
    • 3
      Make any required changes to the settings. Under Security section, it is possible to specify a new username and password for added security. Once you have saved your changes, close the window, and the system will automatically log you out.
Read more: How to Access Netgear Wireless Router Settings ' eHow.com http://www.ehow.com/how_4913660_access-netgear-wireless-router-settings.html#ixzz2H3QQJGxn
Jan 04, 2013 | Computers & Internet
hi how can i secure my wireless network from my home computer
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Oct 24, 2010 | Computers & Internet
How do make my router secure when its states it unsecure
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Apr 28, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
how do i change my password. Guy downstairs is using it and downloading movies.
log into router by typing 192.168.1.1 on the address line of Browser
Username blank
password admin
go to wireless settings and change the WPA key use an old phone number you can recall from memory
Save settings (If you are connected wireless, you'll be kicked off till you log in with the new WPA key)
Mar 26, 2010 | Linksys Wireless-G Broadband Router
how do I put a password on my Belkin wireless G plus mimo router?
it depends on what you specifically want to password-protect: a. protecting the network from unauthorized users? b. protecting the network's admin interface?
for a. - log into your network's admin interface (usually http://192.168.0.1) - go to the category of wireless security - select the type of network protection you are looking for (strength - i.e. wep, wap, wpa2) and set your password following the steps listed within your router's admin interface...
for b. - log into your network's admin interface (usually http://192.168.0.1) - if you have never done this before, then your username should be filled in as Admin and leave password blank and hit enter.... from there, you are able to change or at least add a password to the interface from unauthorized access (usually under category security)
Feb 17, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
575 people viewed this tip
David Payne
David Payne
