Tip & How-To about Audio Players & Recorders
Use a Microfone With An Amplifier (an Amplifier without a Mic Input)
There are number of Amplifiers in the market that do not support Mic function but support a lot of inputs and outputs functions for connecting various Decks,Cd Players,Record Players (Turn Tables) etc.
Now once I had this problem and I wanted to use a mic I tried to look in the front,the back and the sideways and in the catalogue but I coudn't find the solution but then I got an idea...
I thought that a mic is an output device and I need a port where I can plug it in and that port will accept the signals.All I needed was an RC connector at one end (for connecting to the amplifier) and a stereo pin jack at the other end (which goes in to the Mic.)...which infact is easily available at the store (if you know which one to look into).
Now connect it,select the input from the front and go on...sing,shout out aloud and do whatever you like to do...
where is the body control module located on 2002 cadillac deville
The body control system consists of the following 3 modules:
• The Dash Integration Module (DIM)
• The Instrument Panel Module (IPM)
• The Rear Integration Module (RIM)
Each of the 3 body control modules integrate a number of functional systems under the control of a single module. Each module is connected to the Class 2 serial data circuit, many of the control functions are implemented by Class 2 messages.
What system (S) are you having problems with ?
The various RIM inputs and outputs are described in the corresponding functional areas as indicated on the RIM electrical schematics.
The RIM functions include the following:
• Automatic level control
• CIGAR relay control
• Class 2 communication requiring RIM interaction
• Content theft deterrent
• Fuel door control
• Fuel level sensor input
• Heated seat control
• HVAC blower control
• LK/CYL relay control
• Park brake relay control
• Rear defog relay control
• Rear park assist chime control
• Retained accessory power (RAP) relay control
• Reverse relay control
• Transmission shift inhibit
• Trunk release relay control
• Various controls for the interior lamps
Instrument Panel Integration Module (IPM)
The various IPM input and output circuits are described in the corresponding areas as indicated on the IPM electrical schematics.
The IPM functions include the following:
• 54 volt VF display input
• Ambient light sensor input
• Class 2 communication requiring IPM interaction
• Fog lamp switch inputs
• Front HVAC air delivery controls
• Front HVAC sensor inputs
• Front HVAC temperature controls
• Fuel door and rear compartment lid release switch input
• Hazard switch input
• HUD active control
• Instrument panel lamps dimmer switch input
• Ignition switch headlight control
• Interior lamps switch input
• Key in ignition switch input
• Traction control switch input
• Twilight sentinel delay input
The various DIM input and output circuits are described in the corresponding functional areas as indicated on the DIM electrical schematics.
The DIM functions include the following:
• Class 2 communication requiring DIM interaction.
• Control of exterior lamps.
• Control of front fog lights.
• Control of the headlights.
• Headlamps on with wiper input.
• Hood ajar switch input w/export.
• Horn relay control.
• Interior lamps incandescent dimming.
• Low side temperature for HVAC compressor.
• Power moding control over Class 2 serial data circuit.
• Reverse lockout solenoid control.
• Steering wheel controls input.
• Storage of the clock settings and, sending a message out on the class 2 serial data circuit in response to requests from other modules.
Jun 19, 2017 | Cadillac Cars & Trucks
What does bmc mean and what is it for on 1 2001 buick lesabre
BCM - body control module a computer that controls functions on your vehicle . A BCM controls light's , power door lock's , anti-theft system control , Remote keyless entry , headlamps . On your vehicle three modules make up the body control system .
• The dash integration module (DIM)
• The instrument panel integration module (IPM)
• The rear integration module (RIM)
Each of the 3 body control modules integrate a number of functional systems under the control of a single module. Each of the modules are connected to the Class 2 serial data line; many control signals are implemented by Class 2 messages.
The DIM is wired to the class 2 serial data line. The various DIM input and output circuits are described in the corresponding functional areas as indicated on the DIM electrical schematics.
• Control of headlights and exterior lamps
• Lamps On signal with wiper/washer
• Power moding control over Class 2 serial data line
Serial Data Power Mode
On vehicles that have several control modules connected by serial data circuits, one module is the power mode master (PMM). On this vehicle the PMM is the DIM. The PMM receives 4 signals from the ignition switch.
To determine the correct power mode the PMM uses the following circuits:
• Accessory voltage
• Ignition 1 voltage
• Ignition 3 voltage
• Off/Run/Crank voltage
The RIM is wired to the class 2 serial data line. The various RIM input and output circuits are described in the corresponding functional areas as indicated on the RIM electrical schematics.
• The ajar switch and tamper switch inputs from the rear compartment lid
• The automatic level control
• The cigar lighter relay control
• The fuel door lock and release control
• The heated seat controls
• The park brake relay control
• The rear compartment lid release controls
• The rear defogger relay control
• The retained accessory power (RAP) relay control
• The reverse lamp relay control
• The various controls for the interior lamps
Mar 21, 2017 | Buick LeSabre Cars & Trucks
how to connect sony bravia tv to amp
If set has RCA audio outputs, connect the outputs to an input on your amp, say aux, etc. Then set your function control to "AUX" and the audio from your set will be amplified.
Apr 11, 2015 | Sony Audio Players & Recorders
I have a Fender G-DEC Guitar amp and it has an output for recording, can I connect it to the BOSS MICRO guitar input? The Fender amp has many rhythm functions which I am very familar with, besides it has plenty of built in guitar amps and various effects. Lionel
you can use the line in/mic stereo input, but you will have to turn the input level way down to around 1 or 2.
i assume that the record outputd a re rca outs. you can get a rca stereo to 1/8 inch stereo adapter, like the ones they use to connect protable cd palyers to recievers, and then get a 1/8 inch stereo to 1/4 inch stereo adapter form radio shack to complete the connection.
Aug 15, 2010 | Boss Micro BR Digital Recorder
low mic output on BEHRINGER XENYX 1832FX
You don't indicate what type of mic you are attempting to use. From your description, I would guess that you have a mic that requires phantom power. I believe that there is a phantom power switch on your mixer. Try turning that on to see if that resolves the problem. Phantom power will not harm a standard mic. Please update this with your results.
Thanks,
Dan
Apr 06, 2010 | Audio Players & Recorders
1,099 people viewed this tip
 Grubhead
Grubhead
