Tip & How-To about Garden
No Spark at plug on 4 cycle lawn mower engine
1) How have you determined that there is no spark?
2) Have you used a type of spark tester?
3) What is the condition of the plug. Brown or dark brown is OK. Black or silver is NOT Ok.
*If you do not have a spark tester,
a) remove the plug, and with it connected to the wire,
b) find a portion of metal around the cylinder that you can ground it on, and then pull the rope.
c) If the plug is black, you may see spark, but you should replace the plug.
*** PLEASE NOTE ; if there is excess fuel in the cylinder or on spark plug,
it can catch fire, so be carefull to cover the hole with a heavy rag so that any fuel
cannot be exposed to spark plug during test !!!!
Garden Logo
pouland chain saw won't start, seems to not be getting spark
cannot be exposed to spark plug durning test !!!!
Get back with me on how this issue works out.
thanks, rwvanlue
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 26, 2009 | Poulan PP4218AV 18" Chain Saw
no fire to the plug
thanks, rwvanlue
Nov 25, 2009 | Craftsman Garden
echo PB 4500 no spark at plug ran fine for 2 hours stopped for fuel started then died
thanks, rwvanlue
Basics to check:
b) is there spark
Nov 23, 2009 | Echo Garden
no spark 5.5hp honda washer
thanks, rwvanlue
Nov 19, 2009 | Honda Garden
my stihl chainsaw has no spark. spark plug is new
thanks, rwvanlue
Nov 16, 2009 | Garden
209 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
