Tip & How-To about Electrical Supplies
4 cycle engine runs on partial choke only. Float Bowl Carburetor
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your local lawn & garden dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Electrical Supplies Logo
how to prime a rover i5500 engine lawn mower as Icannot start the mower
*if you need gaskets, your Briggs dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Nov 24, 2009 | Garden
engine startsa and runs for two minutes and quits
Nov 23, 2009 | Parks Optical Briggs And Stratton Engine...
My Honda EM650 generator quits running after 15 to 20 minutes. Also the fuel vent line valve leaks while running.
'Vent is leaking while running': can be caused by varnish on the inlet needle/seat and debris in the float bowl.
Nov 22, 2009 | Honda Electrical Supplies
starts,sputters,dies won't run ran well at 2000ft but at about 3000 to 4500 it would not run, replaced on off toggle switch but still no luck
Nov 19, 2009 | McCulloch Electrical Supplies
2,075 people viewed this tip
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
