Tip & How-To about Garden
Replace Recoil Rope on Lawn Mower Engine
1) Remove the recoil housing
**NOTE: normally you DO NOT need to remove the rotor pulley or spring to replace the rope.
This is the area that causes so many guys a lot of extra trouble!
2) Locate the string that is left and the hole it is threaded thru
3) Determine how much string has broken off of the rope that came out
*Note: if more than 1 inch is left, then the rope needs to be replaced
4) Obtained a length of rope appropriate for your engine, it is always better to have too much rope.
You can always shorten if it is too long.
Make sure both ends are melted to a point for easier threading thru handle and rope rotor
5) Wind the rotor in the direction of what the rope would pull,
(this will tighten the spring) until the spring is completely wound.
Remove 1/2 to 1 revolution.
6) Install the rope (with the handle installed on one end) thru the recoil housing and towards the rope rotor.
Tie a knot in the end of the rope, leaving a 3/8" tail free.
Then allow rope to wind onto the rotor until all rope is wound.
8) Pull the rope several times to position rope properly into rotor.
*note : there should be NO droop in the handle after released
9) When the unit is functioning proplerly, re-install housing onto engine.
Garden Logo
how do I wind a stihl ts400 pull cord
1) remove the recoil housing
**NOTE: normally you DO NOT need to remove the rotor pulley or spring to replace the rope. This is the area that causes so many guys a lot of extra trouble
2) locate the string that is left and the hole it is threaded thru
3) determine how much string has broken off of the rope that came out
4) after rope is obtained, make sure both ends are melted to a point for easier threading thru handle and rope rotor
5) install the rope (with the handle installed on one end) thru the recoil housing and towards the rope rotor.
6) with the rotor free of tension, route the rope from the groove toward center and up thru the hole. Tie a knot in the end of the rope, leaving a 3/8" tail free.
7) wind the rotor in the direction of what the rope would pull (this will tighten the spring) until the spring is completely wound. remove 1/2 to 1 revolution, and then allow rope to wind onto the rotor until all rope is wound.
If droop is evident, wind the rotor and rope 1 revolution tighter so there is no droop of handle when released
9) when unit is functioning proplerly, re-install housing onto unit
Nov 21, 2009 | Garden
Starter rope pulley will not pull the rope back into the leaf blower.
Most commonly, the recoil rope rewind spring is broken. However, inspect the recoil housing assembly first to make sure no debris or rope fragments have prevented the rope rotor from rewinding. Always remove the spring 'AS A LAST RESORT'. Many rewind problems can be solved by inspection of the rotor and not have to remove the spring. In case you do, I will include instructions on how to re-install.
Nov 21, 2009 | Craftsman Garden
STEP BY STEP DIRECTION. REPLACE STARTER ROPE. MIGHTYLITE BLOWER MODEL #UT08520
Nov 14, 2009 | Garden
CAN'T FIGURE OUT HOW TO RE-STRING PULL CORD
Nov 13, 2009 | Poulan Garden
i pulled the cord off my homelite 2 cycle leaf blower. can it be fixed?
Yes,
Nov 08, 2009 | Garden
435 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
john h
