Tip & How-To about Garden
Fuel Starvation or 'Lean-Fuel' Condition for ChainSaw, Blower, Trimmer, 2 Cycle Engine
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Garden Logo
hard starting
1) spark plug
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 11, 2009 | Garden
Gas blower won't start
1) spark plug
Remove Carburetor
Nov 11, 2009 | Poulan Featherlite Gas Blower, with Low...
Blower starts but shuts off in run
1) spark plug
Remove Carburetor
Nov 10, 2009 | Garden
my blower shuts off when i excell the trottle
1) spark plug
Remove Carburetor
Nov 09, 2009 | Echo Garden
My craftsman leaf blower will not start.
Basics to check:
1) Spark plug - brown or dark brown - OK
- aluminum or silver - piston/cylinder scored
a) is it carbon or fuel fouled
b) is there spark
2) Compression - 125 to 150 psi
3) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
1) spark plug
Remove Carburetor
Oct 30, 2009 | Craftsman 4 Cycle Blower/Vac
254 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
