Tip & How-To about Garden
ChainSaw, Blower, Trimmer, 2 Cycle Engine 'No-Start' Condition Check
Basics to check for 'No-Start' condition:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Garden Logo
it's flooding how can i fix it
Basics to check:
b) is there spark
Overfuel or 'rich' condition
Basics to check:
b) is there spark
3) Check Air filter for fuel saturation
4) Allow engine to run for 5 minutes remove to excess fuel from muffler
5) Fuel mixture ratio: Make sure the oil mix is per your manufactures recommendations
6) If after the above the engine is still smoking and blubbering:
Adjust carb mixture screws to a 'less rich' setting
*NOTE: only move mixture screws 1/8 of a turn at a time,
and try operation before any more adjustment
Nov 26, 2009 | Husqvarna 155bt Gas Backpack Leaf Blower
need your help
No-start
Basics to check:
a) is it carbon or fuel fouled (black and carbon deposits)
b) is there spark
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 12, 2009 | Garden
I have an Echo Backpack Blower PB46-LN that is leaking black oil out of the muffler, its easier to start when its cold but when its hot it difficult to start, also I dont even need to prime it to get it to start, my concern now is the leaking of black oil from the muffler when its running, what can cause this and how can i fix it?
This senerio is an 'over-rich' condition, most often caused by an improper fuel/oil ratio mix, and the 'exhaust screen' or 'spark arrestor' on the outlet of the muffler is plugged. Cleaning the screen may be all that is needed to correct the problem. **Make sure this screen is clean, and operate engine for at least 5 minutes before making any of the suggested adjustments below.
Basics to check:
b) is there spark
Basics to check:
b) is there spark
4) Allow engine to run for 5 minutes to excess fuel from muffler
Nov 12, 2009 | Echo Garden
My craftsman leaf blower will not start.
Basics to check:
- aluminum or silver - piston/cylinder scored
b) is there spark
2) Compression - 125 to 150 psi
3) Muffler remove for inspection
1) spark plug
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Oct 30, 2009 | Craftsman 4 Cycle Blower/Vac
This Model 358-797251 Leaf Blower will not start. What can I do to make the engine run at the regular speed?
Basics to check:
b) is there spark
1) spark plug
Remove Carburetor
Oct 19, 2009 | Craftsman 4 Cycle Blower/Vac
305 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
john h
